4 wheel drive has stoped
fts1966
L3901
Jul 11, 2026
Sedalia Missouri
Dad’s tractor we have lots 4wheel drive. Jacked it up on 4 stands whe It running and engaged you can feel and hear something rattling in the tub. We are going to pull the shaft. What might we find?
11,150
Read and follow the WSM!
Look at the envelope, top right side of your screen.
4,222
What is a “tub”?
3,738
2,153
What is a “tub”?
A large ussaly oval shaped vessel used by some to bathe in, while others may use it for proofing moonshine. They are commonly found lying around the front yard in certain areas of the country.
11,150
Around here, they also use use them for flower beds, especially the harvest gold, avocado and lilac colored versions. :LOL:
6,774
What is a “tub”?
In context, it’s a colloquial generic name for a case of some sort that contains gears in an oil bath. Could be a transmission case, differential case, transfer case, gearbox housing, etc.
Kind of doubt you’d be able to find it by that name in a parts list/diagram.
netspyder
L3010HST
Jun 9, 2025
39
75
Missouri
th 4wd was making noise when i bought this ol' girl, but it turns out there's a splined shaft underneath that drives the front axle and that was stripped out - easy fix and not terribly expensive. it'd 'clunk' when the shaft would slip, and i was having some anxiety about rebuilding the transmission before i found that. parts diagrams - kubota.com has the same ones messicks has.
Bearcatrp
Mar 28, 2023
1,384
1,007
Minnesota
Red neck swimming pool if sitting outside.
