External 3-point hitch lever
FMG
MX6000HST Cab
Jul 6, 2026
Black River MI
I'm new to Kubota, and in the process of purchasing a used MX6000HST Cab tractor and I'm trying to find a source to add an external lever to raise/lower the 3pt arms from the rear of the tractor. I came from a Kioti and it had the rear lever, LS's I looked at had the lever, but Kubota doesn't offer it. Anyone have a source for after market solutions? Thanks in advance!
4,216
I don’t have a source…. but I have an idea to offer: I added a simple extension to the existing mechanism beneath the fender when I had a N-Ford tractor…using ordinary u-bolts. Worked great for years.
Now that you’ve brought this topic up …. I will follow it…. I want to do it also.
FMG
MX6000HST Cab
Jul 6, 2026
Black River MI
Thanks for the reply, I have a friend of mine who's pretty handy and we're going to look at fabricating this lever. I'll post what I come up with. Still can't believe Kubota doesn't offer this as a kit or anyone else for that matter, even my local dealer agreed with me.
4,216
The Ford mechanism was similar to the Kubota… A simple lever descended thru a slot down to the bellcrank that sat on the shaft which controlled the 3-point. All I had to do was use a simple, straight piece of Rod… and clamped it to the existing bellcrank-mechanism using two U-bolts. The rod was about 24” long…. Sufficiently-long to pass out the back of the tractor beside the Rt Main Tire / above the lift-arm.
(I glued a tennis-ball onto the end to prevent me from “Poking My Eye Out” 😅
7,294
Heres an inspirational video.
FMG
MX6000HST Cab
Jul 6, 2026
Black River MI
Thanks I appreciate that!
7,294
I've seen this video, I think I've searched them all hoping there was a retro kit out there. THanks!!
Just watching the video I did not much care for that design. I think I would incorporate some sort of clamping mechanism in the rear linkage so its only connected to the cabin control when in use. A simple knob you could tighten/loosen as needed would suffice.
An OTS lever operated cable control mounted at the rear seems like a pretty obvious and easy to implement approach.
hodge
Nov 19, 2010
2,960
531
Love, VA
They probably don't offer it because of liability.
FMG
MX6000HST Cab
Jul 6, 2026
Black River MI
