Box Scraper To Move Dirt
392 Goat
11
Grants Pass, Oregon
Hey Guys,
So I need to open up some more land on our southern Oregon property. We have a M8540. Was looking at a box scraper or this Gannon box with hydraulic for the teeth.
Hard to find used cat 2 implements, so im going to have to drop down to a 1 i believe.
Want either a sb3584* box scraper or this guy has a 7' Gannon box that he wants $800 for. Its a 6 hr drive round trip to northern Ca.
Will that gannon work with our tractor? Seems a good price. Is it worth the hydraulics?
Not sure if thats the best route or was thinking about a hydraulic top link with the 3584 box. The gannon weighs 900# i believe.
The 3584 probably less than that.
Our tractor doesn't have a top link atm, so we have to buy some sort of one either way.
I had a guy come out with a mx5400 and box scraper and he ripped right through the ground easily with his mx. We are 2xs the tractor, so i would think either one would work but the gannon looks more hd.
4,258
I’ve never seen a “Gannon” box. Can you show us a side-view?
6,880
What I can see of the Gannon looks fine.
From my experience (others may be different) the hydraulic rippers is a nice to have. A hydraulic toplink paired with a boxblade is a huge upgrade from a manual toplink. If you have only one rear remote, I’d skip the Gannon and get a boxblade with manual rippers plus hydraulic toplink. If you have two or more remotes, the Gannon with a hydraulic toplink could be a decent option.
JasonW
898
605
Al
I have a 7’ Rhino that’s similar to the Gannon, it’s closer to 1200-1300 lbs.
The hydraulic rippers are nice but I don’t need them all the time. So usually I’m spending more time lifting them back up as they drift down. Even if you only have one set of remotes you can make shift something to keep them up out of the way.
Definitely recommend a hydraulic top link. I believe mine was under $300.
But if implements are hard to find used get them when they are available. I prefer to buy used depending on the price.
MtnViewRanch
917
382
Lakeside Ca.
Gannon all the way as long as it is a 7 footer. It is well over 1000lbs. The picture shows a cat 1-2 hitch, so you are good to go. My 6' foot Gannon is right at 1000 lbs.
You need to get a cat 1-2 top link or be prepared to bush down a cat 2 top link.
The tractor end takes a cat 1 (3/4") pin. With the machine's capabilities, you should get a 3" dia cylinder.
Anything smaller and there is a good chance of seal failure.
A good working length for a hydraulic top link for your M8540 is 23 1/4"- 35 1/4".
I highly recommend getting a hydraulic side link also.
If you are grading, you can't beat having all the front-back & left-right adjustments at your fingertips.
Being a 40 series machine, you may not need the check valves as seen in the second picture.
If you need a cost, please fill out the contact page for Fit Rite Hydraulics.
That Gannon new, was last sold for well over $4000. Well worth the 6-hour drive IMO. :)
BAP
Dec 31, 2012
3,206
1,320
Gannon box blades are kind of an industrial blade. They are built Way heavier than other box blades out there and weigh much more. I would buy a Gannon long before I would buy other brands for what you are looking to do.
392 Goat
11
Grants Pass, Oregon
Screenshot_20260705_120116_Facebook.jpg Screenshot_20260705_120141_Facebook.jpg
Yeah I only have the 1 set.
Yeah I was thinking about doing the hydraulic top link for sure. With that box is a good price.So i'm wondering if I could just use the top link with my remote and not have to actually use the gannon hydraulic. Or like, plug it in, pull the teeth up and then unplug it.And hopefully they just stay....
Wow thanks for the great info. Ill look into that top link for sure. Yeah, I think I saw them for under $300.
And I dont mind to drive. So 6 hrs is not bad. I do like how sturdy the gannon is though.....
6,880
Swinging rear blade on the Gannon is a nice feature. Looks very heavy. The replaceable cutting edges look pretty good. At $800 and 6 hour round trip looks like a good deal based on the pics.
biketopia
Feb 15, 2024
446
481
Warrenton VA
That box blade is a beast, go for it. Also, I'd look into adding more remotes and/or a diverter. Once you can make adjustments from the seat, there is no going back. Plus, your machine being the size it is, many implements you may end up with will have multiple hydraulic-acting cylinders, plus not climbing out of the machine is nice. @McMXi has a good thread on adding a diverter to his M series with help and insight from @MtnViewRanch I believe.
392 Goat
11
Grants Pass, Oregon
Hey guys,
Ok so I talked with the guy and got his round about area location. Waited till the next day to check my schedule and he pulled the ad.
I thought he sold it. So I asked if he did. He said no, he changed his mind for the time being.... lol
He had an issue with his tractor and just put everything up for sale. Turned out not a huge deal to fix his tractor. So he said hes keeping it for the moment but will hit me up when he wants to sell it.
So im going to give it a minute and see if I can buy it. The next closes one, same 7' gannon is $1800. So I hope to get the one for $850.
Im going to work on getting that hydraulic top link that you guys talked about and look into another set of remotes. They dont look super hard to add and I have 2 blank grommets i can run through the cab.
