B7500HST Stripped Trans Drain
NKYguy
Cincinnati, OH
Upon a fluid change my right side transmission drain bolt has stripped the threads in the case. I have the trans already drained and tire is off. I"m assuming i'll need to removed the case where the drain is and repair.
What is an effective repair? Helicoil ? Overside plug? Will the case slide off the axle or will i need a puller? Interested in any suggestions and tips on this process including sealant type (black RTV?) and methods.
Thank you
7,280
Thank you
Helicoil snd go. Why cant you do that in place?
7,280
Never used a thread repair. Will the Helicoil hold up when removing the drain bolt in the future? Is it better than a Time Sert? Just concerned about getting it fixed for the long haul
Thanks
Helicoil thread inserts are commonly used in the factory by OEMs to get stronger threads in aluminum parts. Does that assuage your concerns?
You will need the appropriate STI tap and tap drill in addition to the insert itself. Very little material is removed with the drill and then you tap it like any standard tap.
3,097
Timeserts are Helicoils give the same end results = new threads at the original size.
Timeserts are different than Helicoils and I personally like the Timesert design more but that means absolutely nothing to their function.
You can get an individual kit for Helicoil (drill, tap and insert…) but I don’t think Timesert offers that.
whatsupdoc
L3302
Jul 9, 2024
176
201
Thanks
All of the Navy sonar electronic cabinet components that were aluminum
had helicoils installed in every hole.
lynnmor
B2601-1
May 3, 2021
1,803
1,607
Red Lion
So I will pile on. I have a tool & die shop and did a fair amount for NASA, they wanted inserts in all tapped holes.
sardillim
b2650
Nov 24, 2019
130
68
Easton
Thank you
Try a local auto parts store bring in the old plug and ask them for a plus one or a plus 2 plug to replace it without seeing it it's hard to say if this will work I'm going on the assumption that it's a standard drain plug like you would find in any type of oil pan
11,095
They use a standard metric flange bolt for that plug, Just upsize it one size, tap it.
