L355 Service Questions
BergyPatty37
Kubota L355-SS w/L1720 Loader
Jun 14, 2026
45
Maine
Good Afternoon All,
Servicing new to me L355-SS.
1.) How do I go about draining the Power Steering system? Just remove one of the lines and drain the tank? There is nothing listed in the manual other than showing how to check level (dipstick seated not threaded on tank).
2.) For the front axle differential and gearcases, manual shows how to drain and where to fill, but does not tell how much to fill. Is it fill until it drips out of fill ports?
Thanks in advance for help!
BergyPatty37
Jun 14, 2026
45
Maine
I did read that in the manual already.
What i meant with the axles is it did not tell how much to fill in terms of do you fill until it is dripping out of fill ports, or do you fill it until a certain level. There is no dipstick or sight ports obviously.
Or is it just remove it and fill it with the required amounts and thats it.
7,262
You are over thinking something quite simple. You fill it until its full.
Caden
1979 B7100
Apr 16, 2026
252
125
Morning,
I am not good at finding these manual pages, but I think if you first get what you can out of the reservoir, (with some type pf suction device) you should be able to remove a return line and cycle the steering several times to get the rest out. Lifting the wheels of the ground with the loader will help, so you can steer manually.
If you don' t want to do that, I have heard people just draining and refiling the reservoir several times, cycling steering each time, to get the majority of the old out.
If something I said here was incorrect, someone will be along shortly to clear it up. ;)
BergyPatty37
Jun 14, 2026
45
Maine
@Caden Yeah that is probably what I will do, just get enough out and do a service every couple weeks for a little bit. Can never get everything out unfortunately.
Thanks!
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
706
327
Herald Calif.
To drain the power steering system just remove the line from the hydraulic pump. It'll drain the reservoir. You have three compartments in the front axle. Right left and center. You want them half full. Do not fill them completely up to the fill plug. The center section you can look down the fill port and see the oil halfway up on the axle shaft. The outer drives I use a plastic zip tie to stick down to check the level. Half full. Great old machine.
BergyPatty37
Jun 14, 2026
45
Maine
@007kubotaguy Thank you for that information! I figured half full was what the axles required but again just wanted others with experience on that.
Thanks for the help I appreciate it.
Excited to start using the tractor once I get my bucket cylinders back from rebuild and polishing at hydraulic shop.
BergyPatty37
Jun 14, 2026
45
Maine
@007kubotaguy I filled the final drives with the .7 quarts as the manual calls for, and that was pretty much right up to the threads on the fill port. You think I need to drain some out?
I also noticed a little bit of play where that seal is. Not sure if its the bearing or just because the seal is worn and leaking.
007kubotaguy
Dec 23, 2012
706
327
Herald Calif.
Half full. You will never get the amount that the book calls for back in them. They will always have some residual that won't drain out.
