L3650 trans fluid
aemsee
G5200
Jul 27, 2021
Fayette New York
Bought this 3650 recently. Have been accumulating fluids and filters. Could not see through sight glass, so ordered one of those as well. Thought the glass was clouded over.
Nope. That wasn't it. The fluid is milky..and WAY over full. Hopefully changing out filters and fluid will remedy the intermittently reluctant glide shift shuttle valve.
I would like to flush it out, but not at the price of the UDT fluid. Thoughts on refilling it with cheaper fluid just to flush it, before filling with the UDT? I do not see any sparklies in it. 79627ee8-2425-4a94-9519-58fbcfc7c28c.jpg fd03fd54-359e-4ef2-8804-6a1c6af3ee1e.jpg
2,995
If I am not mistaken that is still “mostly“ a gear driven tractor. If you wanted to flush it you could use some cheaper fluid like Traveler UTTF which is equivalent to UDT (but not UDT2 or SUDT2).
But if you just replace the fluid then the new fluid will dilute any contaminated fluid and using the tractor harder will evaporate off the water. If using SUDT2 then that will hold the water in suspension well.
I assume you are at least covering the tractor if you leave it outside for storage. If not, that could be where the water is coming from split leaking seals on top of the trans case.
10,816
So I take it you have a GST.
Elaborate more on the reluctant shifting.
FYI: I can tell you just about every square inch of the inside of the transmision and GST control on thhat unit. I had to go through mine quite a few times when i got it to get it fixed up properly.
aemsee
G5200
Jul 27, 2021
Fayette New York
sometimes shifting between forward and reverse I need to move the lever a couple of times before it starts to move. That is really the only thing I have noticed
aemsee
G5200
Jul 27, 2021
Fayette New York
I have only had it a few weeks, but pretty sure it had been stored outside before I bought it. It will eventually have a home in my barn
10,816
A little is normal on gear change as it's not a perfect system.
but on shuttle it should be within a second or so to engage.
You next step would be to check input pressure.
Do you have the WSM (aka Service Manual)?
aemsee
G5200
Jul 27, 2021
Fayette New York
Yup. Have shop manual, owners manual for tractor, owners manual for engine and just got the parts manual. I am a bit OCD. I'll do the fluid/ filter change next couple of days. See how it reacts with fresh juice. TY
oregontrail
Kubota L3450
Oct 5, 2025
Washington
Interesting yours was "WAY over-full." I just added fluid to my L3450 GST and the little gauge window showed no change, so I kept on adding. I realized too late that the yellow part was probably milky fluid sitting on top of darker fluid. I'm new to this tractor so I don't know what to expect. I plan to flush and change the hydraulic fluid but I'm waiting until I have attached a new loader to it and run it a bit, in case the loader hoses have contaminants in them. Is there any problem with running it over-full for a while?
BTW, the glass looks dirty but it's on the inside.
10,816
Being a GST don't run it too long with contaminated fuild in it or you will be in for an expensive repair.
Water or air entrained fluid fill damage the clutch seals.
oregontrail
Kubota L3450
Oct 5, 2025
Washington
Thanks for the warning, @North Idaho Wolfman. Given that it's hard to see the fluid level in the little round window, I'm not confident about the fluid level. When I remove the cap on the transmission (between the operator's feet) and look in, I see metal that's wet with oil but not covered with fluid; in other words, the gears seem to be sitting in a shallow bath. Is that what it's supposed to look like? If I understand right, the entire hydraulic system has just one continuous reservoir with two filling points (the other being behind the seat), but I would imagine that the 3-point hitch and FEL would both require a source of fluid that has some reasonable volume.
2,995
A lot of people recommend using a dye in the fluid to be able to see it. You may also want to change the sight glass just so it is as clear as possible (but the dye will probably make it easy to see anyway).
If you have a John Deere dealer around they probably have red dye on the shelf like this
There are other brands and colors but none are orange (as far as I know).
10,816
Yes that's normal not to see the fluid looking in the fill port.
You would be surprised how little of fluid is taken by those 2 systems, they just move fluid from one side to the other.
The front and rear fill points both go to the same location.
Get a new sight glass they are cheap and easy to install.
Also if your still having issues adding dye to the fluid makes it much easier to see.
Sight glass:
oregontrail
Kubota L3450
Oct 5, 2025
Washington
Thanks for the advice! Looks like you can just pry out the old one and push in the new (I had assumed that the sight glass was a permanent, immovable part of the case).
aemsee
G5200
Jul 27, 2021
Fayette New York
finally got around to draining the trans/ everything fluid today. Used 4 different containers as I wanted to document the volume. Got 9 gallons from trans plug. 1 gallon from 4wd drain. 1 gallon from each side of the rear drive unit. All 4 rams are retracted. The drain plug magnets were clean. No sparkles in the fluid. Just a lot of emulsified water.
I added 2.5 gallons to the rear drive fill hole. 5 gallons to trans. Fluid at upper half of sight glass. I have not started it since I am still waiting on one of the hydraulic filters.
I drained the trans first until it was just a trickle, then the 4wd plug, then the rear drive plugs.
Pretty sure I found at least one of the water entry points. The vent hose below the seat was split at the elbow and wide open....there is a drain port in the seat pan right above the vent. For now just capped it as there is a vent in the axle fill cap not 5" away from the trans vent.
Once the trans fluid change is all set I will pressurize the trans at the vent to about 2 psi above atmosphere and spray it with soapy water to check for any other places water might seep in. 4cde7ed9-5bf4-466a-bc94-e734d21cfd67.jpg 14125514-9ff8-4b8a-84fd-bbed4deae7c9.jpg dcb25c59-f017-4e51-8835-c38b301022ea.jpg e2427412-f1b4-41ac-9b76-cecb87dc4c53.jpg
