Grapple fittings advice
STEVESC
L2800
Jan 23, 2026
Plan to order a grapple from Everything Attachments for my L2800. There are several options for the fittings. I have no idea which size and style I should choose. Any advice would be greatly appreciated!
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
188
257
Hardy, VA
Fittings? Can I assume you are referring to the hydraulic hose quick connects?
If so, simply figure out what you have on the front of your loader arms and get the same for the grapple.
I would check someplace like www.discounthydraulichose.com first and see if you can get the same fittings for cheaper without any upcharge from a seller like EA
whatsupdoc
L3302
Jul 9, 2024
170
196
You should match the same fittings on the front of the tractor for the third function.
Old Machinist
May 27, 2024
675
795
NE FL
I recently did a DIY 3rd function and added a grapple for my little LX3310. I went with 3/8" flat face fittings and the more I use them the more I like them. When I take all the pressure off to disconnect I just plug the two grapple fittings together. It seems every time I remove and install it the fittings get easier to connect and virtually no fluid loss when doing it.
1/4" flat face are less common but sufficient for a grapple. I mainly went with 3/8" because I wanted maximum flow to operate a mower I adapted.
3,791
2,350
Second this. Obviously, they have to match the tractor. I changed all mine out to 1/2" flat face, but 3/8 would be big enough for OP. I like that you just pull the collar back to disconnect, then the collar stays cocked. So when you push the two parts together, the collar locks without having to hold the collar back while pushing the two parts together.
Caden
1979 B7100
Apr 16, 2026
214
106
I like 90 degree QDs better than the straight style.
If you ever need extra leverage to get them coupled it is easier IMO with the 90s.
Old Machinist
May 27, 2024
675
795
NE FL
That is the only correct answer based on the info provided by @STEVESC
I will add if it were me I would order the grapple with 3/8" flat face fittings and if those didn't match my third function I would change the third function fittings to match. Just saying.
