1988 L2250 Running Rough Under Load
PMore
L2250 with a Woods loader
Dec 22, 2022
11
Wilming il
In January I was plowing tractor was running fine when it started running rough. I replaced the fuel filter with no luck. Sometimes it will start up and run fine until you put any kind of load on it as simple as putting it into gear. Any suggestions would be great need it for some projects around the house.
Thanks
3,099
Biological growth in the fuel is probably clogging the fuel flow out of tank, through fuel lines and fuel system.
Start by looking at the flow out of the tank to the fuel filter. Remove the fuel line and drain it into a clean container but through a paint strainer to catch debris.
There are fuel additives that help break it down and others help keep it clean. If it is in the injection pump and the injectors they may need to be professionally cleaned. I don’t know if the additives can help in that situation but since it does run perhaps you can just add clean fuel with the additives, bleed the system if needed and let it idle for some time to get the additive into the pump and injectors. Then it may need to sit for some hours to break the sludge down, then maybe you can run it harder (but stay close to the shop) and see if it clears up.
Good luck.
PMore
Dec 22, 2022
11
Wilming il
Biological growth in the fuel is probably clogging the fuel flow out of thank, through fuel lines and fuel system.
Good luck.
5,594
Soft fuel lines will do that as well they let fuel through at low RPMs and under load they collapse
