Troy Bilt tiller
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
395
540
SE, NM
Reading another thread about these machines. I think old paint and another member. I have my Dads from 1980. 20 years ago the original Briggs 8 horse decided the rod wanted to be outside. Replaced with a Kohler Command 8 horse. Been tilling ever since. Last week I go to get the garden ready. After sitting outside for about a year(my bad) it started on the first pull. Two cans of fix a flat in one tire and it's still leaking. Got the garden tilled though. I replaced the axle seals a couple of years ago. Those new seals leaked worse than the old ones.
Anyway, this thing is still awesome. Troy Bilt is not the same
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,423
626
Richmond, Virginia
I have a Troy-Bilt Pony, about 25 years old. Power forward and reverse. Small Briggs on it, perhaps 3hp, plenty. The thing never has wanted to start. Always takes 20 pulls. I think it has an auto-decompressor, really not needed on a small engine and that makes firing it off more difficult. Leaks a tablespoon of gear oil a year, I suspect because vines or what ever get wrapped around the tine shaft and into the seals.
6,260
I just sold my last REAL Troybilt Horse( 6hp, single speed,no PTO). Far too big for the garden now. I heard that when MTD bought Troybilt, they dumpstered a LOT of the parts,probably to require you to buy their new version of the tillers. BTW it's cheaper to toss an 'offshore' 7HP engine than buy a NOS magneto for the 6HP Tecumseh engine.
5,333
My old TB is the HORSE, was powered by a Kolar 6 HP I think, well it gave up the ghost. No luck finding any one that would work on the old one so it sat. And I saw a post on youtube, and mounted a HF motor ,,, it is basically a Honda motor, only thing I needed was one longer bolt off the crank, still havent figured out how to use a thumb control for the gas, but at an idle it will pull you outa your socks
6869704x4
Jun 29, 2011
395
540
SE, NM
I forgot that detail. It's a Horse model.
MOOTS
MX6000
Jun 27, 2019
2,224
2,815
Canton, Georgia
You heard wrong. Lots of parts still available for horse tillers. Pony, junior and econo-horse are hard to find some parts for.
MOOTS
MX6000
Jun 27, 2019
2,224
2,815
Canton, Georgia
You need a 72” throttle cable. Amazon and eBay have them. It mounts where the throttle lever is now, but has enough length to wraparound to the side of engine and mount.
MOOTS
MX6000
Jun 27, 2019
2,224
2,815
Canton, Georgia
That was probably me, I was talking to Old paint and NCL4701 about them.
I have 5 horse models at the moment. All in various states of repair/working. Hahaha. Any questions, shoot. I have all manuals and parts breakdowns if wanted.
MOOTS
MX6000
Jun 27, 2019
2,224
2,815
Canton, Georgia
Probably the diaphragm in carb is hard, not pumping fuel/leaking down when sitting. That engine is more than likely a dual shaft 5hp.
William1
Jul 28, 2015
1,423
626
Richmond, Virginia
Not a diaphragm crab, old float style. Starting has been poor since new. Even once hot, restarts are a pain. I'm positive it is the decompl, which on such a small engine, it does not need.
Single shaft, 3 Hp double belt and an idler to twist the belt to run backwards.
MOOTS
MX6000
Jun 27, 2019
2,224
2,815
Canton, Georgia
Shoot me a picture or two if it’s easy to do. I thought all the pony/juniors were dual shaft engines.
William1
Jul 28, 2015
1,423
626
Richmond, Virginia
Kind of buried in the shop seeing I use it now only a few times a year. Also can't see the crank output as there is a large cover that I'd have to remove. I did have it apart earlier this year as I had to pull the engine shroud to clean and lubricate the pull starter (rope would not return).
