A BX, a B, and a L ... ?
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
I would definitely call them. There are sellers using slightly off addresses and similar sounding names. I'd call them using the phone number from their main website and/or look on their main website to see if it's listed there rather than via tractor house.
Shawn T. W
Dec 9, 2024
809
1,467
SW Missouri Ozarks
My guess is that the tractor was/is still at the owners location, as they are a big JD dealer, and it may actually be out on that road ... But I'll definitely call them when I know I have the time to go look at it ...
Saw these old Massey's today, headed for Mexico unfortunately, I'm sure they will put this old iron to good use, or part them out ...
Shawn T. W
Dec 9, 2024
809
1,467
SW Missouri Ozarks
Shawn T. W
Dec 9, 2024
809
1,467
SW Missouri Ozarks
I'm still hunting ...
This is available now, it says it has a mmm but I don't see one in the pictures ... So I'm guessing it doesn't have one, I don't want one!
https://www.tractorhouse.com/listing/for-sale/255498291/2012-kubota-b2320-less-than-40-hp-tractors
A few questions ...
1. On my L I can put my toe under the forward portion of the HST pedal, and lift, and it goes in reverse, I don't like using my heal to back up ... It appears that the red circle is the reverse pedal, is that the only way to back up, or can I put my toe under the green circled pedal and lift?
2. It appears to be at least set up for a loader, but never had one ... Could I just run long lines to these fittings and run the hoses to the back for a top and tilt?
3. What is this yellow knob for?
4. The grill seems to be dented, is there anything close to it inside that could have been damaged? Is it metal or plastic?
I'll be home in 10 days and think I want to go look at it ...
Bee-Positive
Nov 16, 2022
1,091
1,013
Amsterdam, NY
1 - Yes it's a treadle pedal, can use your toe
2 - IDK
3 - Hydraulic oil dipstick
4 - Battery, Coolant Recovery Tank
GrumpyFarmer
5,212
A few questions ...
Good day.
let me preface this by saying I dont have that exact model nor am I familiar with that exact model spec. The am kit sure this helps but my observation from the front quarter layout position:
I think the tie rod looks not correct and also not straight…so I would wonder is that correct? (Looks more like a standard l tie rod IMO)
Since I thought they would be similar but went out and looked at my B and maybe it’s not same model (but I thought would be similar) but appears to be completely different tie rods.
If could very well be all correct, and simply my assumption of similar to my B is flat wrong. (I would want to know that before buying)
have a safe trip
Shawn T. W
Dec 9, 2024
809
1,467
SW Missouri Ozarks
I think they must have changed the design in yours, I like your that's more protected better!
