Hydraulic fluid dipstick question
WV NATIVE
B7500
Jul 6, 2025
10
WV
I’ve got an odd question about the hydraulic fluid dipstick on my B7500.
When I pull the dipstick on my hydraulic fluid it is barely touching the stick but when I insert it again and pull it back out it shows full.
Anyone else have that issue?
It’s the only piece of equipment I own that’s acts like that. I thought the vent may be clogged up but it breathes free.
Not sure which reading I should believe.
Pictures aren’t the best representation but you get the idea. First pull of the stick looks dry - second doesn’t.
leonard65
B2320 tractor
Mar 21, 2026
19
10
Ok same exact thing on my B2320 I never posted it because I didnt want anyone to think I was crazy.Also so hard to read, clear fluid on the orange stick.
WV NATIVE
B7500
Jul 6, 2025
10
WV
If you’re crazy then I guess I am too.
10,803
Put a piece of black shrink wrap on the dipstick or dye in the fluid, to read it better.
5,168
I vote for “dye”.
Cheap, easy and effective.
WV NATIVE
B7500
Jul 6, 2025
10
WV
I can see the fluid - the stick is dry the first time I pull it.
I can’t understand why it’s on the full mark after it’s reinserted. 🤷‍♂️
BAP
Dec 31, 2012
3,142
1,268
As far as the oil being on the dipstick, believe the second reading. I think that because the dipstick has a tight fit at the top, it traps air and doesn’t allow the oil to come up the tube to proper height when the dipstick is in place. When you pull it out, the oil then can fill the tube up properly. Metal dipsticks like in the engine, don’t have that really tight fight at the top so the air can move out of the tube and allow the oil to maintain the proper height.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
388
298
NH
Be interesting to pull the dipstick out just enough to let air in and wait a bit before pulling it out all the way to see if the oil level on the dipstick went up.
I would try this myself, but I don't have one of those machines.
7,554
If at any time the dip stick shows a higher reading then other times go by the highest reading. No matter the physics involved, the fluid is in a container (transmission) and the actual volume doesn't change in any circumstance you describe.
imarobot
Apr 18, 2025
388
298
NH
Very true, but I'd still like to see the physics of why this happens:unsure:
nbryan
Jan 3, 2019
1,414
933
Hadashville, Manitoba, Canada
The o-ring seals near the top of the dipstick prevent the transmission fluid from filling the dipstick tube from below.
The o-rings seals stop the trapped air under them to escape and allow the oil below to rise up and level with the rest of the tranny oil in the case.
Just pull the dipstick and re-check after a few seconds. It's always been like this for my B2650.
Bee-Positive
Nov 16, 2022
910
888
Amsterdam, NY
Put your finger on one end of a straw.
Put the open end of the straw in a glass of water.
Note how far the water goes up into the straw.
Take your finger off the end of the straw.
Shawn T. W
Dec 9, 2024
745
1,366
SW Missouri Ozarks
Hey! At least you don't gotta wipe the dipstick off first, just pull it out, confirm it's clean and dry, re-insert and check again ...
On my Kawasaki in my JD, you unscrew the cap that is the end of the dipstick, pull it off, wipe it dry, reinsert ... BUT DO NOT SCREW IN, just rest on top of the threads, then pull out and check level!
I use dye in my hard to read sight glass ...
That's TWO DROPS per gallon of fluid, I got a LIFETIME supply! (Wear gloves!)
JonM
Nov 29, 2024
252
638
wisconsin
never knew this was a thing ive always pulled the stick wiped it then put it back in to get the reading.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,152
1,739
Pittsburgh
Now my milkshake is contaminated with JD TransGard.
4,092
View attachment 175754 View attachment 175755
It’s not unique to your Kubota. It is also common on Yamaha outboards. It’s due to a trapped air-bubble that escapes when the dipstick is first pulled. The correct reading is obtained after it is re-inserted and then pulled.
Hugo Habicht
G1900
Jun 24, 2024
1,533
2,199
Ireland
The only explanation I have is that despite the vent there is a small vacuum/pressure somewhere preventing the oil to flow back into the reservoir. By pulling the dip stick you remove that and the oil level goes to the correct value.
I remember vaguely that other people mentioned this phenomenon here.
4,092
It’s not hard to understand…when you consider the change-in-design of dipsticks. In earlier designs it was simply a metal blade with a small metal-cup dust-cover…. Nothing air-tight about it.
(In fact, it was a major source/ingress of dust when open crankcase vents were dispensed-with and as the crankcase was evacuated by intake-manifold vacuum.)
The “modern” versions are actually sealed, air-tight with rubber or nitrile ‘plugs” ….that prevent any trace of venting at that point…..(presumably to keep out dust…but also to seal the crankcase for emissions containment. It makes for more effective PCV operations, etc.)
Many newer vehicles have gotten rid of the dipstick entirely to facilitate that system.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,423
626
Richmond, Virginia
My method for a dip stick is always a double pull. I pull, wipe, insert, pull, check level.
5,168
Although it's not entirely germane to the conversation, it's similar.
There are some vehicles where you have to pull the filter BEFORE you drain the oil. If you don't, it creates a vacuum and not all of the oil will drain out.
Our Caravan has such a motor,........................ and "yes" , I found out the "hard way" ......:mad:
So I can see where there might be situations (as @GeoHorn and @Hugo Habicht have pointed out) where the drain/refill systems create, or rely on, a vacuum of some sort. 🤷‍♂️
