RC44G mower spindles
SPaul0989
B3200
Feb 22, 2026
NY
The G4200 I picked up came with a RC44G mower. The spindles need to be replaced, but having a hard time finding replacements. Does anyone have part numbers? I believe the center spindle is different than the outer ones too. Thank you
7,202
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,934
2,332
Western MT
I broke a spindle on my riding lawn mower when I hit a high piece of wood. In any case, I was able to find a matching spindle on Amazon. Pictures online make it look like your mowing deck is very similar to mine although yours is more heavy duty.
There are several similar spindles, but from what I could tell, spindles are pretty universal and the same one will work on many brands. I'd look there and order one that has free returns just in case it's not quite the right one. You could also order multiple ones and return the ones that you don't need.
4,189
My Betsco finish mower seized a spindle bearing. I pulled the bearing and noted the numbers stamped on the bearing-seal…. Googled….. bought a pkg of Ten bearings for less than the price of a spindle.
The replacement bearings have lasted longer than the originals…. still going strong 5 yrs later.
Just FYI
