M7060 Transmission Heat
Simon-Sinister
M7060HDC12, L3250, FORD 9N
Jun 9, 2026
9
North Carolina-Piedmont
Hello, folks.
I pull a BH RDTH72 finish mower behind an M7060 and after a couple hours the transmission gets pretty hot. Hot enough that I can't hold my hand on it. I expect it to get hot but I don't know how much heat is ok partly because this tractor is new to me. We have hills with some flats but the terrain doesn't seem to matter much. I expect high heat is eventually bad for the seals so I thought I'd ask and see what other folks are seeing.
(Mark the date - this is my first post but been a follower for years)
10,852
As long as your fluid levels are up to level, and you're not deadheading the hydraulics you're probably working in the normal parameters of the system.
Get an IR heat gun and take measurements.
I think the M7060 has a hydraulic temp sensor, I'll have to look into that.
4,137
Your hand can only stand (and will feel painful) about 140-degrees F… While many transmissions find that a normal range….. and lots of machinery has oil temps that run 190-210 regularly.… if that helps put things in perspective.
Simon-Sinister
Jun 9, 2026
9
Geo - Interesting perspective, thanks. I am going to check with an IR temperature gun and use that temperature with the numbers you provide and see where it lays. I guess with new equipment I tend to look for trouble while I have warranty protection. I don't recall ever checking the L3250 transmission for heat when pulling this mower.
Simon-Sinister
Jun 9, 2026
9
I got my hands on an IR temperature gun and found the transmission at the PTO to be 171F and for comparison checked the engine oil filter and it was ~ 183f. @GeoHorn, this about fits in with your comments re the typ operating temperature and pain threshold.
Thx folks
