D722 Gear case o-rings
Nwood
Kubota D722
Jun 9, 2026
Australia
Hi, Rebuilt a D722 engine and in the videos I've watched and the manuals say there should be 3 o-rings in the gear case but mine was flush and not recessed for o-rings so I left them out but now I have an oil leak in that area. Does anyone have any experience with this?
10,986
Well the picture you posted is an aftermarket cover and they are know for not doing things correctly.
If you have a stock cover that is flat then you used the wrong gasket, as there are several.
Nwood
Kubota D722
Jun 9, 2026
Australia
Definitely a stock old cover that is flat. I’ll have to call Kubota today and order the correct gasket then because I only used the one that came with the rebuild kit.
10,986
Do you know where did the D722 originally come from?
In other words what was it's original use?
Ag engines are different than Industrial engines?
Nwood
Kubota D722
Jun 9, 2026
Australia
Yes I used permatex ultra gray on both sides of the gasket
Thank you so much for the help
Nwood
Kubota D722
Jun 9, 2026
Australia
Let me see if i can look intto which version they used and see if I can gain any insight.
Did you use RTV along with the gasket?
After talking to kubota the paper gasket supplied with the rebuild kit is definitely not correct so I've ordered the correct one using the serial number.
Thank you for your help.
10,986
Glad you got a solid answer, I had not gotten to looking it up yet.
