TaskStar pump
fmgsr
Kubota, LX2620 - Kubota BX2380 (retired)
Dec 19, 2018
90
47
PA
TaskStar 260W Fuel Transfer Pump Battery Powered, 12GPM Electric Pump Kit with 21V 4.0Ah Battery & Charger.
I got to try out my new fueling system, Cheap, but worked fine. And only time will tell. I didn’t want to dump a 6 Gal. diesel can into the high inlet. I was just barely doing it on the BX, not even gonna try on the LX.
Pump the six gal in about two minutes. If it holds up a year or two, I got my money.
Bee-Positive
Nov 16, 2022
882
874
Amsterdam, NY
That's pretty slick actually and not a bad price either if it lasts awhile. I like the 6' hose on each end.
You state it pumped at 3 GPM (six gal in about two minutes) but it's rated at 12 GPM?
Hugo Habicht
G1900
Jun 24, 2024
1,533
2,198
Ireland
You find that kind of arithmetic with a lot of products today. Good that forums like this here exist to get the truth.
He mentioned pumping up, the 12gpm may be level open outlet, so no counter pressure.
Bee-Positive
Nov 16, 2022
882
874
Amsterdam, NY
Probably benchmark STP conditions.
Still beats my little battery operated HF pump @ 1.25 GPM (maybe).
rh74
LX4020, LA545, LX2980, RB1672, BB2560, PFL1242
Feb 17, 2024
70
81
NY
I have had that same pump for over a year now and it works good. The flow rate is around 6-8 gpm. Which is way faster than pouring from a 5 gallon can. I installed a filter on the outlet as these pumps use plastic vanes. Mine came with replacement vanes, so I assumed it means they will fail at some point and I don't want to fish the parts out of fuel tank when it happens.
fmgsr
Dec 19, 2018
90
47
PA
" Pump the six gal in about two minutes. " was only an estimate. It was fast, too fast to absorb any pleasure of something working as it should!!
