Pulling a 4x4 post - Ugh!!!
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,461
652
Richmond, Virginia
I rarely (ok, never) have had to pull a 4X4 post out.
I had my fence 're-configured', eight guys were here for over a day doing the work. Seems one post they could not get out so they hacked it off just 1/4" below ground level. My wife (and I) wanted to 'fix the area up' and I saw the stub, at first thinking it was a root end. Well, a little shoveling showed it was a post. Ok, I'll get it out! I dug around it about a foot down, chained it and pulled (backed up) with my little BX. Nope, either I went wheels up or the chain came off. Dig more.Now down about 2' and I see concrete. Hmmmmmm Take the bulb spade (2'long bladed round spade) and 'glide it' deep around the perimeter of the concrete. Back and forth with the little tractor. Nope. Life the buck up straight, out glides the 4X4, almost 5' long! Dooh!!! Two hours and a lot of sweating.
Lesson learned
Something stuck straight in the ground, you pull it out straight up, not to the side. I'm sure I'll forget this by the next time.....
Reactions: 6 users
Sawdust&Shavings
Apr 25, 2023
212
254
Stafford, VA
Lesson learned
While it sounds like you were successful, just as countless BX owners before us have…I’m sure Kubota has the PERFECT sized tractor for your needs for a bit less than $100k…just saying!
William1
Jul 28, 2015
1,461
652
Richmond, Virginia
I almost wanted to go next door to my neighbor who owns a concrete company, All kinds of big back hoes (and experience). I was determined.
leonard65
B2320 tractor
Mar 21, 2026
22
10
Ok, did you ever see the wheel method ? hard to explain. you will probaly have to go to Utube. get a car or truck tire and wheel roll it next to the post you want to pull, put your pull chain or strap on top of the wheel attach to the bottom of the post , then your tractor should pull it right out.
Caden
1979 B7100
Apr 16, 2026
250
125
I'm with you there. I'd rather struggle with my own tools than ask for help sometimes.
The only time I pulled posts I had great luck using a bottle jack, leveraging on a 6/6 chained to the stuck post. Saw it on Youtube one time.
William1
Jul 28, 2015
1,461
652
Richmond, Virginia
Yup seen that but no wheels other than the spare from my new pickup.
Mostly, it was the challenge.Worse case was, I would fully hand dig it out.
I've hand dug 2' Poplar stumps (giant tap roots) in the past, because they were there and so was I. One of us was going to give in and it was not going to be me.
The funny part (and lesson here) was a vertical pull. Even the wheel method, as the wheel rolls (and it will) the angle goes off.If... the first time, I'd been more directly centered over it and curled the bucket, it might of popped right out.
Shawn T. W
Dec 9, 2024
793
1,430
SW Missouri Ozarks
Another fairly straight up pull is (and usually more powerful) is to use the three point ...
leonard65
B2320 tractor
Mar 21, 2026
22
10
Yeah, that is true, once the wheel starts to move, it would change the angle of the pull.I sawit but never tried it.
Donystoy
Dec 10, 2013
735
378
Binbrook, Ontario
Reminds of my predicament a few years ago when a wind storm snapped numerous 4 X 4 posts on our fence. I decided to replace a total of 30 posts including some which had heaved from frost over the years. I ended up digging around all the concrete about six inches deep and keeping it filled with water for a couple of days to soften the earth. Some I lifted out with the loader and others where I did not want to damage the lawn with the tractor I used an engine lift. One of the hardest part was breaking up all the old concrete.
7,650
Once you have the chain around the top of the post and the bucket hooked up (and planning to pull up not laterally), go forward a few inches then back a few and it will loosen the post up just a bit to make it easier.
Bearcatrp
Mar 28, 2023
1,377
996
Minnesota
100 lbs of tannerite would have been easier. Just have to fill the crater and find the post that was sent into orbit. Here is a good way to do it.
or go for the gusto and blow it big time….
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
417
314
NH
All these suggestions would not be necessary if you just buy the right tool - an excavator. At least that would be my reasoning 😁
jyoutz
Jan 14, 2019
3,624
2,718
Edgewood, New Mexico
I pull any kind of fence post the same way. I attach an implement such as a blade to the 3ph, back up to the post and lower the implement to the ground close to the post. Then wrap a binder chain around the post and attach snuggly to the implement, then simply lift the 3ph.
Bearcatrp
Mar 28, 2023
1,377
996
Minnesota
Tannerite is cheaper and more fun.
johnjk
Apr 13, 2017
1,799
2,185
West Mansfield, OH
I struggled getting a concrete footer out for an old flag pole. Lots of digging and no real good purchase to chain it. Eventually got it with a lot of mess. I replaced it with another concrete footer but this time I took a 4” eye bolt and put a big fender washer on it and inserted it in to the wet concrete. Will it work? Who knows but I like to feel I’m better prepared and it will let me pull straight up with the FEL and a chain
