M4800 3 pt lift problem
robertb8120
M4800
Jun 5, 2026
OH
M 4800 utility cat II 3 point lift works but the range of lift is only about 12inches from the highest to lowest point(at the very end of the lift arms).Lift has lots power and holds a load well,hydraulic oil shows at the top.Ive seen other similar models and they show about 25-28 inches of lifting range.Can this be adjusted ?is there an internal issue?
robertb8120
M4800
Jun 5, 2026
OH
unfortunetly the lower links dont have optional attachment holes which would increase /decrease the lift range
Caden
1979 B7100
Apr 16, 2026
237
116
I may be wrong but looks like the arms should have 3 sets of holes based on the Kubota website. Could your tractor have the wrong set of arms on it?
7,203
Make sure you have it in position not draft control. Then check and if indicated adjust the feedback linkage.
3,061
Put the top link in the bottom hole at the tractor end and it will lift higher.
4,190
do you have a drill and bits..? 🤫
BTW, I have a set of lower lift arms from my M4700 (similar model to yours) that I removed when I modified my tractor. They are available cheap. The shipping would be a lot more than you simply drilling holes tho’…. ;)
7,203
Does anybody actually read the description of his problem?
"4800 utility cat II 3 point lift works but the range of lift is only about 12 inches from the highest to lowest point (at the very end of the lift arms)."
The lift arms are only moving 12 inches. That is controlled by the feedback linkage!
4,190
Hokie, … he Does Say “at the end of the lift arms.…which implies the (missing) attach-holes in his lift arms might resolve his issue…. And, it has already been suspected his lift arms are not in compliance with the illustrated factory-assembly-parts.
7,203
Hokie, …perhaps….it MAY be you that needs to re-read his post.… as he Does Say “at the end of the lift arms.…which implies the (missing) attach-holes in his lift arms mighty resolve his issue.
Shortening the linkage wont increase travel. It increases lowered height
Before doing snyyhing he needs to
  1. Make sure the lift is in position not draft/mixed control.
  2. Check and adjust the lift travel (feedback linkage) as described in the manual.
Caden
1979 B7100
Apr 16, 2026
237
116
I agree with you on checking feedback.
I disagree with you on the above statement.
Moving holes further towards the rear of the tractor gives you both a lower drop and a higher lift simultaneously, hence greatly increasing travel.
I am referring the the holes on the arm, not in the lifting link.
7,203
He measured travel at the lift pins. Movinv the lift pins rearward (if possible) increases travel but thats not the situation here.
Here's an L3901 - much smaller tractor. Lift travel is almost 18" . If his tractor is only lufting 12 inches (when in position control) its not adjusted properly or the mechanism is broken.
Sawdust&Shavings
Apr 25, 2023
209
250
Stafford, VA
I was wondering if anyone else in the world still used a folding rule, good to know that they do.
It’s a very popular item in my world. I even have a book on Stanley folding rules…
4,190
I’ve still got my Dad’s Lufkin, w/6” narrow-brass extension. :D
robertb8120
M4800
Jun 5, 2026
OH
Appreciate your comments.I suppose the links could be modified or replaced with links that would provide a greater lift range.I'm familiar with the draft control's influence on the position control.I'm thinking the feedback linkage adjustment may be difficult to access/adjust.
3,061
The feedback linkage is easily accessible on open platforms (not sure about a cabbed model but probably also accessible from the rear of tractor).
Here is the parts diagram that shows where it is located.
7,203
The feedback linkage is easy to access - its right on the left rock shaft. Check and adjust it with nothing on the lift - 10 minute job. Make sure draft control IS NOT ENGAGED.
