Seal kit for 1630 front end loader cylinder
mealj123
Multiple kabota products
May 31, 2026
So does anyone know the proper kit number the one that they sent is not the proper one
netspyder
L3010HST
Jun 9, 2025
44
90
Missouri
here's what i did when i got mine and needed to do the seals for the lift cylinders, and pretty much have found everything i've needed for this old '98... go here
looks like you'll need the serial unless its a 'C'. kubota has all of the exploded views with the original part numbers for pretty much everything. assuming the cylinders are original and haven't been replaced, look for the kit in the parts list, then search for that number on amazon or messicks - or you can order from your local dealer if its something specific that needs an oem part - like hydraulic hard lines.
good luck!
