M105S Fuel Prime/Bleed
Aeromechanick
Kubota M5700 Hydraulic Shuttle, Kubota M105SHD, Vrisimo Flails
Mar 14, 2025
11
Tehachapi, CA
Hello all!
I have a Kubota M105SHD with Rops.
I am doing fuel system maintenance, (filter and water separator) and my workshop manual refers me to a fuel system bleed procedure.
It says I should bleed the fuel system of air, and it references a hand pump “knob” on top of the fuel filter assembly.
When I look there, there’s a cover plate with a phillips screw and no pump feature.
Anyone know what’s up?
Caden
1979 B7100
Apr 16, 2026
245
124
I was looking at the diagrams but don't see it with the injection pump diagram or the fuel system diagram.
If I were you I would look in the general vicinity. Maybe directly on the side of the block above the filter housings.
3,665
2,087
Hello all!
Try to depress the "cover plate."
I think you will find that it moves up and down with a side benefit of pumping fuel. ;)
Aeromechanick
Mar 14, 2025
11
Tehachapi, CA
LMAO, if that pans out to be the case….well I’ll be in your debt.
Will report back tomorrow.
May take a video if things don’t go favorably so you see what I see.
Aeromechanick
Mar 14, 2025
11
Tehachapi, CA
Alrighty, I went and messed with that knob using a bit more force, no go.
Not sure if the bleed/prime pump is seized, or if mine simply doesn’t have that feature.
The file attachment feature wouldn’t allow a video, please see pictures.
Caden
1979 B7100
Apr 16, 2026
245
124
I looks like that thing on the top of the filter housing has to be it... not sure if it'll mater but did you open the bleed screw first to make sure the pumper isn't air locked somehow?
3,665
2,087
I have never found one that stuck, mush straight down using some force, they are very stiff to depress.
Attack it like it owes you money!!
11,757
I don't have anything to add @Aeromechanick other than to say that your M105SHD has one very nice and well maintained engine compartment. Impressive for a tractor of that vintage. Nice job!
Aeromechanick
Mar 14, 2025
11
Tehachapi, CA
Yeah I gave it hell.
I don’t have little bish hands either 🤣
The knob is pancaked down onto the lower housing. I removed the knob and sprayed the lower brass section with pen-oil, will see how that goes. So far no joy.
I looked up replacement parts and you can clearly see the knob is elevated, and even a spring below that would enable pumping action. Mine doesn’t have that. I’ve also lifted the feature with damn near eagle tallon force…it won’t budge.
She 22 years old, happy to throw some OEM parts at it.
Will keep everyone posted until resolution so this thread helps anyone else.
SINCERELY appreciate each of you!
-Nick
Bee-Positive
Nov 16, 2022
1,014
957
Amsterdam, NY
Maybe a non-oem brand? Yours looks different from the OEM.
I looked up the part # on K-Pad and then searched for that part.
The OEM has the knob on top that the manual refers to,
Sorry for the late reply
Aeromechanick
Mar 14, 2025
11
Tehachapi, CA
Replaced the existing fuel filter assembly with a new OEM unit from Messicks.
Also replaced the water separator assembly as the existing one was a bit long in the tooth.
The new filter/pump unit had an obviously different pump feature, leading me to believe that the spring was removed from the unit that was previously installed, and the pump feature was thoroughly seized.
New pump bled/purged efficiently and tractor fired up just as the service manual described.
Success!!
Thank you all very much for your help!
