Pressure washing - do’s and don’ts?
tallguy104
Kubota B2301
Nov 3, 2021
9
Australia
I’m wanting to give my B2301 a good wash before selling it. Any tips?
Can I pressure wash most of it or are there certain areas I should avoid spraying directly?
Caden
1979 B7100
Apr 16, 2026
315
182
If you spray the radiator, hit it straight on from a distance to avoid bending fins.
Avoid the air cleaner.
If you use hot water watch out for rubber hoses, seals, and lines.
Trustable
l2501HST
Jul 5, 2022
397
411
The stickers, especially those on the loader and any LP implements, do not hold up to pressure washing in my experience. I would avoid even using a 40 degree nozzle around them. The stickers on the tractor itself seem to do fine with pressure washing.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
423
315
NH
Pressure washing around bearing can force water into bearings
Old Machinist
May 27, 2024
723
841
NE FL
Keep your distance. DO NOT SPRAY OIL COOLER OR RADIATOR!
5,527
As @Old Machinist suggests….I would also advise using caution if using more than “standard hose pressure” on anything that appears to look like a "radiator."
I did this, and had to spend an hour(ish) carefully straightening the fins back out with a pick.
Luckily I stopped before I damaged too many fins…….
Old Machinist
May 27, 2024
723
841
NE FL
Most of us that offer this advice should follow up with "ask me how I know". :)
7,685
I've always thought washing a tractor should be high pressure like rain! Are some guys more particular? ;)
Trustable
l2501HST
Jul 5, 2022
397
411
Also, definitly grease all zerks after. It helps ensure if any water did get in the loader pins and frame that the water will get pushed out.
notaz3
98
97
ID
Grease it until all the old grease is replaced with fresh.
Wash it with detergent of choice.
Grease it again just enough to push out any water.
Or the way I do it... Leave it uncovered during a rain.
Trustable
l2501HST
Jul 5, 2022
397
411
I have none left at this point.
Yeah, I’ll be getting there eventually. I don’t wash my tractor much besides using a hose to get mud or dust off. But when I do power wash it twice a year or so I always take a sticker off. The implements have very limited branding at this point as I wa
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
612
638
Lake Almanor, Ca
I have owned mine since 2009…never washed it. Drove fast to blow the dust off…
