M7060 3PT return line blows
Al38kit
M7060
May 20, 2026
texas
There is a small hydraulic return line just behind the cab.
It is hooked to a T fitting and then the two lines connect to the hydraulic cylinders that lift the 3 point hitch.
Anyone else have issue with these lines coming off the T fitting?
I wired them on last time and tonight they both blew off when I lifted the big mower.
Ideas?
2,942
I assume you are talking about the air vent line shown highlighted below. I assume the cylinders are single acting in the upward direction under pressure and gravity downward. That would mean that no hydraulic fluid should on that side of the cylinder. Therefore, I think you have a leaking seal on one or both of the cylinders that fills that upper side of the cylinder and when you lift the three point hitch it forces the fluid into that relief hose and blows it off the fitting.
Al38kit
M7060
May 20, 2026
texas
Thank you for the insight as to how this should work.
It explains things very well...I'll check the cylinders individually tomorrow.
That makes good sense as I could not figure out why the return line (which it's not) was made that way.
I'll plan to buy cylinder rebuild kits...anyone know how difficult it is to do these small cylinders?
Thanks again.
11,750
Thanks again.
Look at page 7-S27 in the WSM which provides good instructions for rebuilding the lift cylinder. Here's a section view of the lift cylinder and the outlet that connects to the return hose.
So you must have signs of oil in that return hose, right?
Al38kit
M7060
May 20, 2026
texas
Al38kit
M7060
May 20, 2026
texas
Yes, massive fluid in the return line.
This happened again last night as I was lifting the 10' mower.
Thanks for the information.
Al38kit
M7060
May 20, 2026
texas
The lift must leak down pretty quickly then.
That is correct.
I’ve been chasing some issues with the three-point and hopefully I have found the problem.
IF both of the 3pt cylinders are bypassing and leaking, does anything think there may be problems with the overall hydraulic system pressure?
Is it normal for hydraulic pump to be heard?
Last night I think the sound was the noise of the fluid bypassing the cylinder(s) on the return air line.
I'll get at it today and see if it's one or both of the lift cylinders.
11,750
I only hear the hydraulic pump when turning the steering wheel, but that's when it's loud enough to be heard over the sound of the engine. Perhaps I should be more specific and say that I hear a sound when I turn the steering wheel when moving slowly and it's related to the power steering. I say slowly since the steering wheel is typically turned more when moving slowly, and the rpm are often reduced at those times which in turn makes it easier to hear things. I hope that makes sense.
Your question re hydraulic pressure would depend on the rate at which fluid can escape but I can't imagine your leak is sufficient to change the operating pressure within the hydraulic system. You need resistance to build up hydraulic pressure, just like you need resistance to apply a torque. But without putting a pressure gauge in the system it's all guessing right.
Al38kit
M7060
May 20, 2026
texas
I found both cylinders bypassing really badly, one a bit worse than the other, so I pulled both of them... they weren't too difficult to disassemble.
The lower seals on both of them were almost non-existent.
I could not find parts at Kubota but called a local hydraulic shop who said they probably had parts. They could have rebuilt them in a week or so...I went to see them and they had parts for the upper and lower seals. I did not pull the seal on the ram rod itself as it wasn't leaking.
Total bill was $40 and I got everything back together late this afternoon and they appear to work fine, although I haven't put a load on them yet.
There is a bushing in the arm assembly that is shot and I need to order that, but it looks like I'm back on track.
Thank you gentlemen for your input.
