New to me L225
3,400
Hello,
Purchased a L225 last year to mow a small property. What a great little machine.
This forum has been a great resource so far!
I could tell you love it the moment I saw you rolled out the silver carpet for it!
3,134
What’s a good paint color for the early Kubotas?
Seems like there are choices?
See this link for colors and years of production
There is a serial number stamped into the transmission case on the right side (I think). You can take that to a dealer and they may be able to look up when it originally was sold.
Tractor data dot com says the L225 were made from 1974 to 1976.
Caden
1979 B7100
Apr 16, 2026
314
181
Old Kubota Oragne is the real color I think. More of a red orange than the modern.
When doing mine, I looked at Allis Chambers Orange, which was a close match.
Ended up going with Chevrolet Engine orange and this was the result on my 1979.
Caden
1979 B7100
Apr 16, 2026
314
181
Also, the blue on mine is completely incorrect, it is Ford blue.
Yours should probably be a midnight blue gray like mine should have been Not like the grey today. I was unable to find this color anywhere which is why I went with the royal blue.
11,199
found the serial number, having trouble looking it up??
You can't "look it up", take the number to a local dealer and they will tell you what year it was sold and that is the year of the tractor.
I can tell you it's not a grey.
Brownie289
L225
Oct 21, 2024
9
11
Woodstock CT
One more question (famous last words) this is an adjustment for lowering the 3 point hitch? I see the knob is missing, is this a big issue to fix? It is hard to lower the mower smoothly...I hade just dumping it.
Thanks again....
11,199
Shaft must be broken inside or you would have fluid shooting out.
Send @007kubotaguy (lance) a message and ask if he has one.
Brownie289
L225
Oct 21, 2024
9
11
Woodstock CT
Grease the throw out bearing? I saw this on a video of a L185 restoration. Looks like it’s behind an access plate?
Also more good news I was able to find 2 decent fenders and a non cut up dash from a salvage yard. They are headed to a local sandblaster soon. I think I’ll leave the hood as is, the minor dents give it character, just scuff and repaint.
3,134
Technically not the throw out bearing itself. That bearing is on a carrier sleeve that slides along the input shaft. There is a grease fitting on the sleeve that puts grease into the area between the shaft and carrier.
The cover should be on the right side of the bell housing and probably one bolt holding it on. I just add two pumps from a grease gun every year to 18 months.
