What is "splitting" a tractor?
leonard65
B2320 tractor
Mar 21, 2026
22
10
Sorry, Dumb question,
Ok, I have to know, what is splitting the tractor ?
3,055
never a dumb question!!
Basically a split occurs when the clutch needs to be changed. Sometimes other part need to be changed too. breaking the tractor from front to back is the split!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Welcome aboard!
I'm no mechanic but I split my Ford 1210. It was easy because it isn't a big tractor but the basics are the same. Removed unnecessary things that would get in the way - in my case that was hood, fuel tank and battery. Then remove or disconnect anything that crossed the joint of the engine block/bell housing. Several wires and hydraulic lines. Support both halves of the tractor. I used a cable come-a-long from an overhead attachment point for the front and made a "kickstand" for the back half. Then removed the bell housing bolts and wiggle/pry it apart.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
604
617
Lake Almanor, Ca
It is really something you don’t want to happen…if needed, pay someone else to birth the clutch.😎
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
415
311
NH
It is something very expensive that is done to a tractor :(
7,621
A lot of variables would be the determining factor of expense. Size of machine, for sure. Is the machine being sent to a repair shop or doing yourself?
If you are mechanically inclined at all separating a tractor is not a big deal. You disconnect anything that restricts removing the engine from the transmission. Be aware of some safety practices, like blocking the tires, wedges on the sides of some engines, proper jacks, patience. Oh, maybe a good coach or two, and the internet!
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
There is no single frame from front to back. Parts in the front are attached to the engine, parts in the rear are attached to the transmission/rear axle.
Random Google image example-
6,575
... and this is not the proper way to split your tractor. 😯
Not per manufacturer recommendations, but it’s incredibly quick. When you have to beat book time to make rent, shortcuts can happen. 😉
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
551
183
NZ
Clearly a production-line process to make the massive investment in the railway cost-benefit work. My bro' chose the cheaper way of cart-wheeling his tractor down a steep hill.
