LX4020 ROPS lighting help
Agent Splat
LX4020 PR1672
May 9, 2026
WI
Hi there, I'm new here.
I have an LX4020 that I'm wanting to install forward and rear facing lights on the ROPS. Watched a bunch of videos and found instructionals online about it, but nothing specific for the LX4020. I cannot, for the life of me, find any sign of this magical "auxiliary light" connector that is supposedly somewhere on here. I read "under the left fender" or under the seat somewhere for LX and BX type models, but I find no open ended connections available. I don't see anything around the wiring that goes the the existing factory installed lights.
Anybody have insight? Thanks in advance.
3,102
That connection is often wrapped with blue tape and then tucked away and taped down with black tape to make it disappear and difficult to find.
I would take a trip to the dealership and ask them to show you where it should be located.
Good luck!
3,723
2,141
The power supply connectors are at the RH fender.
Agent Splat
LX4020 PR1672
May 9, 2026
WI
Thanks for the input. They pulled a sneaky on me and it’s actually just under the toolbox in the center, tucked behind some conduit.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,174
1,162
E.
Follow up question…looks like the aux power fuse is 10amps. I’m not particularly electrically inclined. Any idea if this kit work within 10amps? https://a.co/d/06NeEQRm
nope... way too much light for 10 amp fuse
watts / volts = amps
so 330 watts / 12 volts = 28 amps + you will need a safety factor above this so maybe a 35+ amp fuse
Trustable
l2501HST
Jul 5, 2022
397
411
Honestly those look pretty sketchy based on the Amazon description, but even if I ignored that you are well above 10 amps with those. At around 28 amps, I would want at least 10 gauge wire and they are advertising 16 gauge, so that’s not good IMO.
To calculate amps on a DC power source use watt/volts. For AC it’s a bit more complicated I think you have to use a power factor, I’ll be honest I have no idea what that is. The only reason I even know about the DC equation is because I literally just bought some hardware (UBolts, nuts, washers, etc) this past weekend for some ROPs mounted lights and have been looking at which lights to purchase and mount.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
132
131
Lakes Region, NH
Honestly those look pretty sketchy based on the Amazon description, but even if I ignored that you are well above 10 amps with those. At around 28 amps, I would want at least 10 gauge wire and they are advertising 16 garage, so that’s not good IMO.
To calculate amps on a DC power source use watt/amps. For AC it’s a bit more complicated I think you have to use a power factor, I’ll be honest I have no idea what that is. The only reason I even know about the DC equation is because I literally just bought some hardware (UBolts, nuts, washers, etc) this past weekend for some ROPs mounted lights and have been looking at which lights to purchase and mount.
Wrong, you apparently do not know about the "DC equation". MapleLeafFarmer is correct DC amps=watts/volts.
Bee-Positive
Nov 16, 2022
1,086
1,009
Amsterdam, NY
As a retired Energy Engineer:
DC or AC doesn't matter the formulas are the same:
Amps = Watts / Volts
Watts = Volts x Amps
Volts = Watts / Amps
A power factor of 1.00 is perfect for any system or piece of equipment.
Power factor for LEDs are between 0.90 to 0.99 so not even worth considering in this case.
SDT
Apr 15, 2018
3,689
1,414
Wow! Thats a lot of power for LED lamps.
Your wiring harness is not suitable for such power regardless of fusing.
I suggest a dedicated relay wired with 12 or even 10 AWG wire.
I installed a HF LED light bar on my B3350 ROPS, since sold. Hint: If you plan to use your tractor around trees/brush, mount the lamps and light bar on the inside of the ROPS to protect from branches, etc.
Trustable
l2501HST
Jul 5, 2022
397
411
It was a typo :). I have edited it to reflect what I was trying to say. I was able to pull the amperage so I just have been doing something right 😆
Trustable
l2501HST
Jul 5, 2022
397
411
Good to know, thank you!
Agent Splat
LX4020 PR1672
May 9, 2026
WI
Thanks for the help everyone. After a lot of research I'll plan to run the power off the battery with an inline fuse, power the relay switch off the aux connection. Then I can go a bit more crazy with lights.
jspicerreachnet
11
Belleville
Although those calculations are correct its based on the wrong info supplied. There is no way these LED lights draw that many watts. They are just stating that as a comparison to old style light bulbs. Note they state the lumens at 5,500 I just checked a normal LED bulb that states 8,000 lumens and uses 18 watts . Using your previous formula makes it draw 1.5 amps on his 10 amp fuse. Even if these are poor quality and less efficent thay can draw triple and still be OK. The devil is in the details.
