120vac to 24vdc
Stmar
B2650HSDC
May 23, 2017
948
58
Buffalo, Wyoming
I have a 24vdc full size refrigerator, fused at 15 amps runs at 7.5 amps. Now it is run by a battery bank but they are getting to the end of their life cycle. I am researching step down transformer and power supplies in the 360 to 500 watt range. Any suggestions on transformer vs power supply? From what I found the power supply seems to have more options and safeguards. I have an electrical background but am a bit rusty on this subject.
sagor
Jan 9, 2017
307
88
Sudbury, ON, Canada
Just buy a switching power supply, there are lots of them on places like Amazon. The usually cost less than $50 for ratings around 360W to 600W (24V supplies). They are regular 120VAC input.
Get something with a higher wattage rating, as any startup current may be twice the running current. Some switching supplies don't like heavy startup currents if they exceed their maximum running current.
6,240
check with 'wheelchair' service centers ! they use 24 volt ! Have 2 on the shelf, gifts that I've never used.
if you want to make your own.... 16 volt, 10 amp power transformer, bridge rectifier 100v,20A , and 10,000 mfd/50v cap would be the 'basic' power supply.
Stmar
B2650HSDC
May 23, 2017
948
58
Buffalo, Wyoming
What is practical about a 24 vdc fridge if you are leashed to 120v supply ?
The alternative power system came with the property, right now the practical side is that you have refrigeration when/if the grid power goes out, which is a rare occasion now but frequent in the past . I am thinking of the future for when the battery bank gets to it's end of lifecycle, replacement cost will be about $4,000.
