Homemade joystick conversion
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
777
1,409
After getting advice from Dan @TheOldHokie and others here about the best valve setup for my old B7200 I had talked myself into buying a joystick valve for the loader rather than making bits to adapt to the 3 spool valve I've got. The 3 spool valve wasn't the best way to go but I didn't know that when I bought it and the bloke at the local hydraulics shop obviously didn't either.
Well, I couldn't help myself. I had to have a go at making my own joystick bits (maybe it's a disease ?). What's the worst ? If it doesn't work I'll convert the valve back to standard and buy a joystick valve.
Mix in some scribbles, some turning and milling on the lathe, some grinding, drilling and tapping, plasma cutting and welding, and today I ended up with something that I'm pretty happy with. There are some finishing touches and some covers and boots to add tomorrow, but I like how it's turned out.
Play at the end of the handle is about +/- 10 mm up and down (a good part of that is end play in the raise/lower/float spool) and +/- 5 mm sideways, and it feels nice and solid.
The single handle is also in a much easier to use location than the 2 separate handles were before.
Here's the dodgy drawings I had to work with - better have a word to the draftsman.
Reactions: 8 users
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
Your projects and attention to detail are in a class above mine BUT we seem to have similar thoughts on drawings. Here are my "detailed drawings" and the completed cab. I did have access to CADD, but sometimes it's easier to just jump in and be flexible:)
Paul Allwood
Jul 8, 2025
777
1,409
Thanks Chim. You're cab looks great. And your drawing must be good - it obviously worked.
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
406
179
Southern Worcester County, MA
Dude, do you ever stop???!! ha ha ha Love the fabrication skills! Looks great and I am sure you'll enjoy it alot more.
Paul Allwood
Jul 8, 2025
777
1,409
Haha - I do. What you see is the result of a mad flurry of activity in between periods of struggling to get going. And thanks.
11,757
This is what I started with before I tried to make an elephant! šŸ˜‚
Reactions: 6 users
11,757
Engineer's reply.... Apart from the front view, I note you've used 1st-angle projection. We use 3rd-angle protection in Australia šŸ˜‚
I can't take credit for the drawing. We use 3rd angle projection too! :ROFLMAO:
Paul Allwood
Jul 8, 2025
777
1,409
So today I made a temporary bit that held everything in place that made the insides visible as I couldn't get any decent pics or videos inside the real cover/mount.
Here's a few photos and videos with some explanations - apart from why I did this in the first place, I hope these makes sense.
This is looking at the face of the valve where the spools enter. I made this plate to replace the normal die-cast covers that mount the standard operating levers. The plate holds the retaining washer and sealing o-ring in place in the same way. Apart from the small holes, this plate was all turned on my lathe.
Here it is with the plate in place.
Now with connections to the spools. I used threaded rod here to allow adjustment. Within reason, it allows me to adjust the resting position of the operating handle. I milled the u-shaped bits that fit over the spools on my lathe - I don't have a mill but I do have a milling attachment that sits where the post goes. It's slow but it works.
Here's a view of the bits that combine the two separate spool operations into a single handle.
A bit closer.
From the back.
This shows the top and bottom vertical pivots - bearings rather than a steel pin in a steel hole, plus one on both sides of the moving bits to maintain alignment and rigidity for the whole mechanism.
Did I invent this ? Well not really. I took an old design and I think I improved it. This is not mine, but it's what I based mine on....
Videos next.
Reactions: 6 users
Paul Allwood
Jul 8, 2025
777
1,409
Staying with the temporary bit to expose the insides, here are some videos showing the operation of the moving bits.
Paul Allwood
Jul 8, 2025
777
1,409
I was looking through the photos and videos to create the above posts thinking you really have to have the right target audience for this stuff.
My psychiatrist who treats my PTSD is quite a funny bloke with a really quick sense of humour. When we chat he always asks what I've been up to. One time I explained that I've been really enjoying making bits for an old tractor we bought, and looking forward to get out to the shed. Straight away he said "I better write this down, excited about tractors, could be a problem". Luckily he said it with a smile.
Reactions: 6 users
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
561
190
NZ
Thanks for showing those pics and videos, they really brought it to life. I tried to figure out how to do something similar a couple of years ago and gave up. You are a clever guy :)
Paul Allwood
Jul 8, 2025
777
1,409
Thanks John. As I said above, I didn't really invent it, just modified am old idea.
Your profile says you're from New Zealand - we're almost neighbours.
Paul Allwood
Jul 8, 2025
777
1,409
A bit more progress today. Made an end cap and modified and fitted a rubber boot to protect the joystick guts.
I also re-made the piece that attaches to the boom spool to make assembly and disassembly a lot easier.
Reactions: 6 users
