Ballast ?
Onekawboy
B2601 w/ 3rd function and Chinese 1 ton mini ex.
Dec 15, 2025
Central Illinois
Wondering if anyone has filled there LX rear tires
14x17.5 with ballast trying to get a solid (close to accurate) number of gallons per tire … i have figured about 48 gallons i’ll need which is 23-24 gal per tire
7,223
3,057
I would - game changer. Hard part is deciding what fluid and what to spend on said fluid.
24 gallons is spot on btw
Onekawboy
Dec 15, 2025
Central Illinois
prob going with RV antifreeze or washer fluid figure Menards w / 11% is a good route
3,057
wind shield washer fluid is cheaper and is close in weight to the RV antifreeze for what its worth.
Bee-Positive
Nov 16, 2022
1,007
953
Amsterdam, NY
Here's a lbs. / gal comparison to estimate weight added.
Lbs. / Gal Fluid
6.50 Methanal Alcohol
7.60 Windshield Fluid
8.33 Water
9.60 Antifreeze
10.85 Beat Juice
11.60 Calcium Chloride
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,936
2,334
Western MT
Do consider the toxicity of the fluid both to the wheel and the environment if you get a flat.
For me, Rim Guard (Beet Juice) was the best choice. Dealers also will come to you to fill your tires in some areas.
Onekawboy
Dec 15, 2025
Central Illinois
Missed out on the RV antifreeze being on sale .. so prob do washer fluid again thanks all ….
Onekawboy
Dec 15, 2025
Central Illinois
48 gallons (24/24) per rear tire completed
Each tire prob took about 30-35 minutes ( including) bleeding air off
Use of the weed sprayer to hold the fluid was great.
Since I already did this on my B2601 i had no other up front costs other than the fluid…
this group has been great owning one of these orange tractors … as has been youtube
ty
