Kubota bc 23 w/ 60 min mount making too much noise?
Drty9
Kubota BX23 with FEL and BH with 60 mid mount deck
May 15, 2026
USA WV
When I bought the mower I took the deck off and completely redid most of it, new blades paint job, changed fluid, power washed, new belt and checked the bearings in spindles which seemed really tight. When I put the deck back on I made sure to align the splines on the mid PTO. Maybe it’s me but the deck just seems loud. I looked at a few other forums and did things like check to make sure the splines were properly aligned because sometimes wear can make them align incorrectly but these are nice sharp splines I also rechecked fluid level and looked to make sure the belts were put on correctly. I also took the mid PTO off and ran it without the deck to see if that bearing was the problem. Everything checks out. I’m wish I could post a short video of me with the tractor running and engaging the deck.
Drty9
May 15, 2026
USA WV
Go To my instagram to view the video. I can not get it to upload here. I have tried multiple different ways. Thank you!!
Instagram.com/jeffreyckennedy
10,678
Can't see your Instagram post as you are set to private
Upload the video to YouTube and give us a link to see / hear it.
Bee-Positive
Nov 16, 2022
775
777
Amsterdam, NY
As S&S said above it doesn't sound obnoxious.
Did you check the new blades to see if they're balanced from the factory? Maybe check the runout of the pulleys and shafts and that the pulleys are all on the same plane relative to each other.
