tube screen filter
wcullers
l3750
Apr 19, 2024
arkansas
Does L3750 tractor have a tube screen filter in addition to the twist on filter? I cannot see one on parts diagram. If there is a tube screen, where is it located. I see some models have them, but I wonder if the L3750 is somewhat different.
11,315
No the l3750 does not have a screen.
It uses a magnetic plug to do the job.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
709
331
Herald Calif.
This is a common problem with your model tractor. It is the lining from the break disc. If you remove the large line that comes from the rear axle housing to your hydraulic pump at the transmission you will probably find that it is full of this material. Not sure what caused this. I have seen many l 3750 and L 4150 with this problem over the years. Don't let it go too long as you will end up with metal to metal contact on the brakes and pollute the whole system with fine metal particles.
