Engine wont shut off with key
bert jobes
Bx2360
May 13, 2026
MN
Hi All,
Was mowing and engine shutdown in the bx2360. It did restart , finished mowing but when i turned the key off the engine continues to run...i put in a new fuel solenoid after checking fuses .. no go.
Replaced the otc timer, still no fix.
Running out of ideas.....
Anybody?
3,639
2,062
Hi All,
Anybody?
Use the WSM and perform a proper diagnosis rather than start changing parts.
10,941
Yea just firing the parts cannon can get real expensive real fast, and rarely fixes the issue. ;)
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,614
How about taking some voltage measurements at the fuel shutoff solenoid, post them here, and maybe we can figure it out together.
And while we're at it, how did you check the fuses?
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
355
235
Eastern PA, USA
Obviously you managed to get it shut down somehow. Some insight into how you managed that, just might help diagnose the actual problem.
bert jobes
Bx2360
May 13, 2026
MN
Replaced all the fuses i tested with a test light and problem solved. Apparently you cant rely šŸ’Æ % on a test light...
Thanks to everyone who reached out .
Ps. I bought the WSMšŸ˜Ž
