Having some weird issues with the starter igniter wire. Just wondering if anyone has a schematic I can look at before I open up harness. Thanks
Only if there was a book that had that info....
Oh wait there is, WSM to the rescue!
Look at the envelope top right of your screen.![]()
If the 900 is like my X2 it already has a starter relay under the seat, and there is also only one safety switch in the circuit. That is a great mod for tractors and mowers with multiple safety switches causing voltage drop. I have done that to a BX and a ZD.You may want to look at adding a relay into the solenoid firing circuit like this. It will overcome a lot of problems since it requires little power to close the real power circuit that is more directly from the battery positive terminal.
