Engine quits with no warning sounds
Derf
4630 GST tractor with cab
May 2, 2026
Colorado
On my L4630 GST, I have been using a friend's chipper/shredder on the PTO, and it works fine for about a half hour, then the tractor shuts off with no indications it's about to quit--no bogging down, no shuddering, it just stops. I can restart it immediately but it shuts down quicker after that. I don't see any idiot lights when I restart, but I'm not in the cab when it shuts off.
I bought the tractor used 4 years ago, and this is the first implement I've tried using the PTO. It never quits while I'm driving or in the seat, but I can't feed the chipper, obviously.
I've read some threads about stall protection shut-offs and seat/occupant switches, but those don't seem to apply, unless there's something that gets warm over time.
Anything else I could check?
#40Fan
539
375
Is there a button that you press that allows you to run the PTO without being in the seat?
When you restart it, and shuts down again, are you sitting in the seat or outside at the chipper?
If yes to both, try setting a bunch of weight on the seat.
10,688
Does the seat tilt forward?
On ROPS models you tilt the seat to the steering wheel to keep it running when running the PTO and not in the seat.
Derf
May 2, 2026
Colorado
I haven't had to press anything, just move the PTO lever to the operating position while standing outside the cab. Since it runs for awhile, it doesn't seem to need any weight on the seat.
Derf
May 2, 2026
Colorado
When you don't tilt the seat forward, does the PTO not even engage? Or does it run for awhile (sometimes 45 minutes) before stopping?
And does not tilting the seat cause the engine to quit, or just prevent the PTO from engaging?
2,907
The PTO safety system should be shutting your tractor down immediately if you are not in the seat and the PTO is on.
Therefore, you have something going on with the PTO safety system that delays the shutdown but eventually does shut your tractor down.
There must be some way to tell that PTO safety system that you are leaving the seat but need the PTO to continue running. Kubota has a couple of different ways to tell the tractor that. Two of those methods were stated above.
Please try the method that @North Idaho Wolfman suggested and see if the tractor runs continuously with the rear PTO turning.
You might tell @North Idaho Wolfman the tractor serial number and he might be able to look up how Kubota designed the tractor you have. We don’t really know if the cab is original or an aftermarket version from where we are.
10,688
No the seat tilted forward should allow the PTO to be engaged and allow the tractor to continue to run.
My though might be a slow reaction of the seat switch is causing a weird shut down situation.
Derf
May 2, 2026
Colorado
@Russell King and @North Idaho Wolfman
Thanks for those comments. I'll try to see if it keeps running with the seat forward. That would definitely be the best/easiest solution. Maybe the seat-forward detector is faulty until it runs for awhile, then it makes the connection and shuts the engine off
Hugo Habicht
G1900
Jun 24, 2024
1,506
2,159
Ireland
Could it have to do with a faulty safety switch wiring? A friend had a similar problem (not with PTO though); he could operate the tractor for about half an hour and sometimes only for five minutes and then it would stop; pretty much at random intervals though typically shorter after it had stopped and being restarted. Turned out to be a faulty seat switch that came into contact with the chassis.
Derf
May 2, 2026
Colorado
I'm confident in the one part of my seat switch, because it shuts off if I start to leave the seat while in gear. But if there's a separate connection to the PTO that is does the same thing unless the seat is up, then it makes sense that it would be similar to your description.
That's one of my tasks for today, so I'll let you all know.
10,688
Most have mutiple seat switches, one for gear sense and one for PTO sense.
I would have to look at the WSM later to know if you have 2 or not.
Derf
May 2, 2026
Colorado
Update:
I ran the chipper for over an hour and a half, keeping the seat forward, with no shut offs. I even tried bouncing the seat in normal position to see if it would trigger the shutoff, but it didn't. The only thing is that I shut off the engine a couple times when the chipper gummed up with pine needles. Not sure if that would cause the problem to reset, making it less likely to occur??
@North Idaho Wolfman: I can see the one switch, which is probably the gear sense, but I haven't looked too hard for anything else.
10,688
Update:
Yes that tractor has a dual contact switch for the seat.
Derf
May 2, 2026
Colorado
No, there is 2 switches internally, only only arm
Ok, so a dual contact switch, to my mind, tells me that it makes one contact when sitting on the seat, and another contact when the seat is lifted, and there must be a third (no contact?) position when the seat is down but not occupied. Do you think the logic of the different safety mechanisms uses the position (3-way) of the same switch to make all the decisions?
Or am I completely missing what you're saying?
10,688
It's senses seat with back side on it, or not, so that's two states.
Third state overrides the first 2 when you tilt the seat forward.
