BX23S Backhoe Dolly Build
David T
BX23S TLB, Pallet fork, 60" Rotary Belly Mower RCK-60B-23BX, 72" 3PT Pine Straw
Mar 8, 2022
22
30
East Garafraxa, Ontario Canada
Does anyone have the dimensions or a rough sketch to fabricate a dolly for the backhoe for my BX23S? Seems pretty simple in construction and I have all the material. I just want to make sure I have any critical dimensions correct.
SmilingKnob450
BX23S
Nov 20, 2024
Central Ohio
Followed these dimensions and used pressure treated 2x4s as that's what I had on hand.
Several made from steel in that thread as well if you're going that route.
David T
Mar 8, 2022
22
30
I have completed the BX23S Backhoe Dolly and have posted pictures with my drawing. Works great. Used 1-1/2" 304 SST Square tube as this what I had. (I work for a great SST piping fabricator who donates to my cause occasionally) Used 3" HD Wheels with overall height of 4.3". Mower Deck dolly is next.
fordbogger
Bx23s
May 1, 2026
5,088
View attachment 153064 View attachment 153062 View attachment 153063
Very nicely done sir!
I have considered making a steel one, but the project list keeps growing…...
The only thing I would change, would be the wheels.
I have found those HF 6 inch wheels make pushing the BH around “A Breeze” on my wooden version….. (y)
JonM
Nov 29, 2024
237
597
wisconsin
here is what i did for my bh92. 8ft 4x4 and 2x6 all pressure treated. i used second pair of 2x6 under the operator seat where the stabilizer arms sit to distribute weight better. i used 4 inch wheels as many as needed to take the weight. your bh77 is going ti be lighter. but the critical area is under the stabilizers at the lowest point. that measurement will determine your max wheel size. to get length just make the arm vertical like your going to take the bh off and measure.
bh92 happens to hit about 8ft.
just make sure your back end where the seat is, is fully tilted up on storage or it will collapse over time meaning you will have to hook up the hydraulics at a wierd angle to readjust so you can move it around.
if you tuck it away and collapses the wrong way good freeking luck getting it out of a small tight area.
you want it like this not how i have it in the first pic. you want the back end as high as it will go so it wont bleed down over time. that sucked to fix:
