PSA - Tire Losing Air
Bee-Positive
Nov 16, 2022
1,134
1,055
Amsterdam, NY
Just an FYI for anyone interested.
Over this past snow season I noticed my left rear tire would lose air over a couple of days and I could find no obvious air leaks. No bubbles around rims or tread. So I just lived with it until the weather warmed up and I could get a good look at it. The weather warmed up and it seemed to have stopped leaking. Went out the other day and sure enough almost flat. WTF!!!
While putting air in the tire yet again I noticed the stem in the air valve was partially unscrewed. After 15 minutes of digging I found the little air stem tool and tightened it down. Problem solved, hasn't leaked since. Checked the other 3 tires and they were fine.
In 50 years of working on all kinds of cars, motorcycles, and tractor it's the first time I've seen a valve stem come loose by itself. I've never even had the tire off or fiddled with the stem in the 4+ years I've own the tractor.
We all know about checking the wheel lug nuts periodically but I've never heard of checking the air valve stem.
Reactions: 6 users
Speed25
L2501(sold) - BX25D
Apr 23, 2024
347
534
NC
I've developed a slow leak in one of my fronts, so definitely worth grabbing my stem tool to at least rule this out. Thanks!
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,475
667
Richmond, Virginia
I was taught long ago, to always put a drop of soapy water on the stem to check for leaks, even tight, they can be defective, probably replaced a few dozen in my life. On a tubeless, I also put soapy water where the stem protrudes and wiggle it, looking for leaks, Found a few split ones.
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
You need to watch those valvestems, especially the rubber ones that can dry rot, had some tires from Walmart that they did not replaced the valve stems and going down the road. The centrifugal force would bend it back to where it would leak out the air took a while to figure that one out and destroyed a tire or two and the company would not back their negligence.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
347
534
NC
I suspect centrifugal force isn't a problem for the valve stems on my BX! :ROFLMAO:
Sticks and other debris might be though...
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
355
235
Eastern PA, USA
My b7200 had hte same issue. No bubbles, but over the course of 3 days, flat.
So I said screw it, and got a tube off amazon for $30.
2 hours of screaming and cursing later, boom. No more leaks. I don't care where the leak was, and now it's not my problem anymore.
Beware, the valve stem was to big for my valve hole, so I had to drill it out. Real pain in the dick, but i packed the inside with greasy rags to catch any shards.
When putting the tire back on the rim, 2 big c-clamps, not even tightened down, will keep the tire from coming up if you have a crappy HF tire changer like I do.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
398
542
SE, NM
Same with the low side charge port for the AC. High side have to replace the port itself.
Bee-Positive
Nov 16, 2022
1,134
1,055
Amsterdam, NY
Kind off topic but I found it interesting the Schrader Valve was patented in 1893.
If it ain't broke don't fix it.
Schrader Valve according to Wackypedia
August Schrader was a German-American inventor and businessman. In 1844, he opened the Schrader company, a shop dealing in rubber products in Manhattan, NYC. Around 1890, after reports of English cyclists' success using pneumatic tires, August Schrader saw the need for a bicycle tire valve. Working with his son George Schrader, in 1891 they produced the Schrader valve, which was patented in the U.S. in 1893.
In 1845, he began supplying fittings and valves for rubber products made by the Goodyear brothers.
5,652
I knew a guy that had a problem like that one time, figured he was not going to fight a tube and getting the tire back on the rim , 2 jugs of slime and as far as I know it is still holding air
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
Just had a similar experience this past weekend on the LX2620 I bought last fall. Plowed all winter with no problems, then went out Saturday to do a quick job and found the right front tire not only flat, but rolled off the bead. It must have gone flat a few days earlier when I parked it, and I didn't see it getting off the machine.
Figured I must have found a stray nail, but couldn't find anything. Pulled the tire off, took the seat out to get enough air flow to re-seat the tire on the bead, then re-installed. I keep a spray bottle with a mix of water and dish soap just for checking tires, and couldn't find any leaks. Checked everything twice and nothing. Hmmm. I've checked it several times now and PSI hasn't budged. Near as I can figure at this point is that, yes, the valve stem loosened up.
