Timing Gear Case oil service? - Kubota Ek1-261
janbon
Kubota Ek1-261
Aug 7, 2024
Sweden
I just noticed this oil filler cap on my Kubota Ek1-261. There is no dip stick.
It seems to be for the timing case, but I find no mentioning of it in the manual.
i am wondering what the maintenance requirements for it are, does anyone know? Just trying to be proactive here, no malfunction.
7,303
I’m making an educated guess as I’m not familiar with that Kubota model.
Engines often are used in a variety of machines/applications. What might be in a tractor or excavator could also be used in a generator set, refrigeration unit or marine application.
They sometimes have “extra” oil fill ports on them to accommodate the different applications/configurations that they may be used. Those ports likely lead to the same sump/oil pan, but aren’t as accessible in different configurations.
If you research the model of the engine itself, you may find reference to the additional fill ports.
janbon
Kubota Ek1-261
Aug 7, 2024
Sweden
Thanks for your input. That sounds plausible. I assume we are talking engine oil here?
It is a three cylinder Mitsubishi engine in this one. Model: MVS3L2-Z564ET
The tractor is manufactured in India after Kubota bought a stake in a local manufacturer there.
Bee-Positive
Nov 16, 2022
771
772
Amsterdam, NY
According to the operators manual it's right next to the filter (assuming it's the original engine).
janbon
Kubota Ek1-261
Aug 7, 2024
Sweden
Thanks, i knew the location of the engine oil dipstick. The question was regarding the purpose of the filler cap on the timing cover on the opposite side of the oil filter.
Bee-Positive
Nov 16, 2022
771
772
Amsterdam, NY
The hydro filler cap is shown below so I would think that's the engine oil filler.
