ZG127S Electrical
foretexas
ZG127S
May 5, 2026
Doing repair work, I knocked 3 wires lose by the solenoid. I have a green wire coming from the key switch area with a female connector, a blue wire coming from the bundled harness with a female connector and a blue/red wire also coming from the bundled harness and also with a female connector. The solenoid has one male connector open. I've arced the main terminals and the engine turns over, I've tried each of the 3 cables connected to the open solenoid post but engine does nothing. I've searched the area and see no other possible male connectors.
Thanks
Bee-Positive
Nov 16, 2022
708
724
Amsterdam, NY
Here's a picture of the wire harness. Not sure how helpful since the only parts available other than the whole harness are fuses and grommets.
6,237
The WSM will have the colour code, usually page before the diagram
from memory..
B black
R red
GY gray
Or orange
Br brown
RY red, yellow stripe
YW yellow ,white stripe
WG white, with green stripe
RW red, white stripe
G green
