LX cab lighting
Onekawboy
B2601 w/ 3rd function and Chinese 1 ton mini ex.
Dec 15, 2025
Central Illinois
Wondering if anyone would have the Kubota part number(s) for the rear work light kit for the LX2610 - i tried looking them up on Messik’s but no luck.
Thanks
Bee-Positive
Nov 16, 2022
971
926
Amsterdam, NY
I would think the kit #B7345 ($265) for the LX2620HSDC (buildmykubota dot com) would fit your LX2610.
Ask your local dealer. There may also be less expensive options out there.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Not sure how your cab came from the factory, but mine was prewired. There was a connector behind a blank in the ceiling and wires taped (hidden) on the upper rear blinker wires. With a the pricey Kubota plug-n-play switch and a pair of Maxxima MWL-42 lights it was easy. To connect the lights, i cut the factory ends off and butt spliced them. They mount on a couple tabs that bolted onto the existing brackets .
Donystoy
Dec 10, 2013
734
377
Binbrook, Ontario
Strange how some of the LX2610 cab tractors came with these lights installed and others did not. Mine that I purchased in the fall of 2022 came with them. I certainly did not add them to my order as I never drive my tractor in the dark.
Onekawboy
Dec 15, 2025
Central Illinois
Maybe 2023 it became an option for rear work lights …
Old Machinist
May 27, 2024
694
805
NE FL
Here is another thread on this topic you might find interesting.
