Tilt cylinder repack on b7200
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
361
239
Eastern PA, USA
I have a kubota b7200 with L1640 loader. One of the tilt cylinders needs repacked, it's spewing fluid. I took it to the hydraulic shop and htey quoted me $500 to repack the cylinder.
I got a huge sticker shock on it to say the least. I'e never had to have one done before.
Is this normal, i kind of need it, it's that time of year. I dont' want to do it myself, but the next cylinder that goes i'm pretty sure i won't have any choice.
7,372
I assume its a B1640 loader. Toss the old cylinders in the recycle bin and buy two new ones for half that quoted price.
Caden
1979 B7100
Apr 16, 2026
352
197
For my job, I work on peanut combines. I recently took two cylinders, much larger than that, off a combine and had both rebuilt for around $650.
To me $500 seems pretty high for that.
fatjay
Nov 12, 2016
361
239
Eastern PA, USA
Unfortunately i'm pressed for time or i would absolutely fiddle iwth it myself. It got the jump on me when I need it, so i'm at their mercy.
7,372
where do you get the new ones? It's a 1640 loader. I need hoses pretty bad as well.
Nothing special about the cylinders. You can buy them from any number of0o online sources. They are 1.5" bore but I dont remember the length. Measure the fully retracted center to center length of the one you have and I will point you to an online source. Probably $150 each and you need to replace them in pairs. You can buy 3/8" R16 hoses with female JIC ends ready to go from Surplus Center. They come in 6" increments which work just fine. Prices sre great. For example 18" hoses for the 4 workports are $12.50 each.
fatjay
Nov 12, 2016
361
239
Eastern PA, USA
Back together. Done for now but i'm really curious about getting new hoses.
Some of the connections I'm not sure would withstand the disconnect process, let alone a new connection.
The main concern I have is that one on the hard line that is pretty rusted.
fatjay
Nov 12, 2016
361
239
Eastern PA, USA
Any idea what sizes i'm looking for and what types of connections?
And surplus center can make them for me cheaper?
7,372
Surplus Center does not make hoses. They sell hoses in premade lengths. They are svailable in 6" increments. Measure the old hoses and order the closest length you can get.
The oriiginal hoses were 3/8" with a mix of end types. I suggest you convert everything to JIC-06 female swivel ends.
You will need some of these for the pipes and cylinders. Put them in and you never touch them again.
The valve had a mix of straight and elbow fittings. Post some pictures to see exsctly what you have.
fatjay
Nov 12, 2016
361
239
Eastern PA, USA
Thanks. I need a 12' hose for my b8200 and didn't want to think about buying a replacement from my normal shop.
7,372
For anybody visiting this thread in the future the B1630 / B1640 cylinders are a common size and there are lots of sources for replacements. Because the are a matched set always replace them in pairs. Here is one source
Boom cylinders
Bucket cylinders
fatjay
Nov 12, 2016
361
239
Eastern PA, USA
Boom cylinders
Bucket cylinders
What are the chances i can replace just one bucket cylinder now? $121 is a great deal considering i just spent $600 to repack the othe rone. Now the original one is leaking like a siv.
7,372
They are not going to be an exact match at full extend and retract. That is likely to cause some twisting action that will get the boom out of sync side to side. How much and how bad is hard to predict. You could try one abd see. If you have to buy a second its still a lot cheaper than rebuilding the old one.
fatjay
Nov 12, 2016
361
239
Eastern PA, USA
I bought 2. It's leaking pretty good and I have work to do with it. I figured it would balance itself betweent he two if they weren't even, but yeah at full retract there's twisting and that's asking for trouble on a 40 year old machine.
fatjay
Nov 12, 2016
361
239
Eastern PA, USA
I want to replace all the hoses. They're in rough shape.
I saw an online hose place it's about $30 a hose. Cheaper, but I am not sure what size hoses or fittings I need.
I think it's NPT on the rest of hte loader, but I'm not sure what size hose or thread.
4,036
2,486
I'm not familiar with your loader or tractor. But I hate NPT on hydraulics, and Kubota commonly uses JIC female flares on their hoses, using adapters on the ports to get to JIC.
Ordinarily, you have 3 choices
1. Kubota dealer - easiest, but probably most expensive. This is probably not an option for you, they're probably NLA for a rig that old.
2. Exact aftermarket replacement - a. you can take the old one to a hydraulic shop or auto parts store (maybe) and have them duplicate it. This may work if you're in a bind, but tends to be expensive. b. (my favorite) measure the hose and ends and order on-line. Discount Hydraulics, and I'm sure others, have references for measuring. Just be careful, Kubota likes to use #8 (1/2") nuts on 3/8" hoses, but sometimes uses #6 (3/8") nuts. Summit Hydraulics also does custom hoses.
3. Install fittings where required to accommodate standardized hoses. Surplus Center sells standard length hoses with straight JIC swivel ends cheap. If your current hose has an angle end, you can install an angle fitting and use a straight hose end. Sometimes you may need to go from #6 to #8. And, you'll usually have extra hose to deal with. An advantage to this method is that you can keep just one long hose as a spare for any of the others.
