Kubota L3300
jomch
Kubota L3300
Jul 25, 2021
37
Georgia
The PTO shift on/off stopped working my old L3300 -- any suggestions would be appreciated. Thanks -- Joe
10,945
I suggest you consult the WSM on how to test its operation.
Look at the envelope top right of your screen. ;)
jomch
Kubota L3300
Jul 25, 2021
37
Georgia
Wolfman-
The WSM really wasn't much help, unless I missed something. What I do know now, that I didn't previously, and it may not make a difference, but when engage the tractor clutch, the rear PTO disengages. I just can't get it to disengage with the on/off lever. When the lever is moved on/off, it appears that the cable and all connections are moving as they should. Any more suggestions on what to do next? Thank you!
10,945
What sub model L3300 do you have?
F, DT, GST?
10,945
Yes, pressing the Main clutch will stop the PTO, that is right.
The WSM should have a section on adjusting and testing the PTO valve pressure.
That's where you need to start.
The make up of the system : 3-M15 3-M16
Testing and adjusting the system: 3-S21
