Show us your Shop and Equipment
Yooper
3901 LA525
May 31, 2015
1,752
930
NE Wisconsin
That’s just crazy cool, Bill! Those small parts on a mill are the most challenging IMHO.
3,590
And here is the result from running 5440 RPM on several operations to make the above parts.
(nearly 30yr old belt)
5,581
Oh snap!
When I first clicked on that, I originally thought you were making dimes……hahahahahah
I was immediately thinking that Bill was going to soon have to change his screen-name to “Bubba’s Bitch” when the Secret Service clicked on that page.
NOW I get it….watch parts…..
very cool man!!!
As you were…….Carry on sir!(y)(y)(y)
3,590
For those who have never seen a "1 J" style head torn down:
3,590
Ran across a vid of the finest, most versatile machine I ever ran.
Spent a lot of time on one of these during my training, because more common, standardized machines weren't available to our training class unless they happened to be open & unused on 3rd shift.
So while most of the class sat at a bench reading text books, I was running this beast.
Used it as a vertical & horizontal mill, shaper, and a lathe.
I once power tapped some parts in steel with a 4" x 10tpi tap.
Very powerful.
5,581
Very cool man.(y)
I am getting ready to yank mine apart very soon….
3,590
Scored again.... nearby thrift shop does a dollar day sale the last Sunday of the month.... every item is $1, no matter what.
Got a solid carbide burr, a 5/16" 5C collet, a 1/2" R8 collet,, a 3/16" R8 collet,, a #3JT R8 arbor, a 1" R8 shell mill arbor, and a 1"-8 thread plug gage.
All items were normally $5-$10 each.
Plug gage is like new, the rest are new. :)
5,581
Thats an awesome score!
Hmmm…..maybe I should start going to our local thrift store? :unsure:
3,590
Estate sale today, $1 each.
Insert tools are Kennametal.
BXHoosier
BX24
Jan 21, 2018
513
634
Indiana
Moved my oak Gerstner tool chest from the house out to the shop. Going to build a riser for it and set it up on the bench in front of my mill.
3,590
Upgrade:
Old- 1/4hp, 820 to 3100 rpm, 4 1/2" throat, hgt from under chuck to base 11".
New- 1/2hp, 620 to 3100 rpm, 5 1/2" throat, hgt from under chuck to base 16", window in cover to see belt location, crank up table, "Laser Trac" sighting system.
New one was a gift from the wife's uncle & aunt in Indiana on our recent trip back there to help them out with various things/procedures/problems/needs.
Yooper
3901 LA525
May 31, 2015
1,752
930
NE Wisconsin
Just a neat size for doing probably eighty percent of the things we drill!
3,590
I often do jobs where I have to swing the head over & hang parts off the table.
(1st pic)
Whenever I do, I have bumped my noggin on the DRO shelf/arm 11teen times over the years.
The DRO sits on an aluminum bar bolted to the ram, and pivots back & forth.
(2nd pic)
I checked the stock/parts stash and came up with this.
I screwed a 3/4-10 threaded rod into the ram & locked it with a nut.
I then took a 4 1/2" diameter piece of Lexan, faced one end, drilled it thru with a 3/4" hole, and counterbored it to clear the nut.
Then I faced the other end, counterbored that end to recess another nut.
Added a thin polypro washer, the aluminum bar, another thin polypro washer, and a Nyloc nut.
This will give me another 7 1/2" of cranium clearance. :)
Everything was on hand except the Nyloc nut.
5,581
(1st pic)
(2nd pic)
View attachment 180465 View attachment 180466 View attachment 180467 View attachment 180468
Nice job!
Love that holding set up in the first pic too......(y)(y)(y)
Also, while looking at your set up, I need/want an accurate way to measure the up/down of the quill.....So I'm thinking of getting a single axis DRO just for that...
Got so many damn projects going at once though....... :unsure:
I finally after "years and years" (~25 yrs🤷‍♂️)of holding up the long pieces for my horizontal bandsaw, with various cans/things.....
Like so......
I finally took an hour'ish to make some dedicated stands
Can't believe it took me so long to "whip up" a couple of these...🤷‍♂️🤷‍♂️:unsure:;)
5,581
What brand and size is your bandsaw?
I'm not sure exactly (I'll verify when I get home) but I think it's a 6 inch "KBC" brand.
I used to drive by one of their showrooms daily, and I seem to remember picking it up on a "whim" about 25-30 'ish years ago, when I began "dabbling" in metal working.
It's not great at any one particular thing, and not "super accurate" but it's one of the handiest little saws I have ever owned for sure..... (y) (y) (y)
DaOtherOne
BX23S
Aug 23, 2021
208
925
Main Bay with track car and tools
Tractor bay with all of the yard related equipment.
