A trench digger that isn't a backhoe 😂
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
775
1,407
This afternoon I had a go at making something aimed at digging trenches or tree stumps down to about 500 mm. Turns out it's a not very good version of ones that are sold by Good Works Tractors in the US.
Once again I used scrap that was laying around in my almost depleted offcuts stock.
The one I made did ok, but struggles to hold and clear the dirt. Oh well, nothing ventured, nothing gained....or learnt.
I think I'll cut off the front bits, buy a sheet of 3mm mild steel, and modify it to be more like a real one. The benefit here is that if I only use a small amount of the 8 x 4 sheet, I'll have a big offcut for the next project.
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
That’s how invention works. You start with an idea and see what works and more importantly, what doesn’t work and improve on that. I like to say that Henry Ford didn’t build a Rolls Royce in his garage, but his jalopy lead to it over time.
Paul Allwood
Jul 8, 2025
775
1,407
Absolutely. 35 years of R&D in the gas appliance industry in Australia....I used to tell people that most of what we did ended up in the bin. Then when we got what we wanted we put it into production. Welding scrap bits of steel together to use with an old tractor isn't quite as complex, and doesn't have quite the same safety implications, but it's keeping me occupied.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,344
865
under a rock
Rebar to the rescue....
has probably been used in more applications than the original intent.
:cool:
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
Would it work better to set it up to dig in the opposite direction? Rotate the channel 180°. As the digger is pulled and raised it may drag the loosened material out of the trench being somewhat contained by the trench walls and the digger itself. When a backhoe digs, it benefits from that arrangement.
Used in the current configuration I picture much of the loosened material being pushed back into the already-opened trench and only removing whatever material remains on the channel by virtue of its angle of repose.
Sawdust&Shavings
Apr 25, 2023
222
265
Stafford, VA
Worth considering on the FEL or the 3-point…I think you’re onto something.
Paul Allwood
Jul 8, 2025
775
1,407
That may well be a worth a try, and not too difficult to modify to try it. Although that is close to how I tried it - pushed it into the ground moving forwards and lifted. I drove back a bit to take the pics.
It might also make it similar to back dragging with a bucket in a fully dumped position, with the dump cylinder close to or at full extension and in compression with the digger being pulled back towards the tractor. I have no experience with it, so don't know if it could really be a problem, but have read and heard in videos that this can lead to bent cylinders.
Maybe to dig backwards the digger section would be better pointing straight down in line with the SSQA mounting face ?
John T
May 5, 2017
1,344
865
under a rock
I saw a guy on the Youtube who took a long section of thick angle iron and chained it to the bucket with chain binders.... then ran the tractor in reverse..... dug a nice little trench.
Paul Allwood
Jul 8, 2025
775
1,407
Is this the one you saw, or something like it ?
Not my video - copied the link from YouTube.
John T
May 5, 2017
1,344
865
under a rock
yeah, I think so....
but notice is is dragging through basically 3/4" process... :ROFLMAO:
it wouldn't last 3 seconds in New England....
7,680
You would be able to easier and deeper if the channel piece was lower on the attachment plate.
Thomas Edison said, "To invent you need a good imagination and a pile of junk".
11,198
I hate to say this, but the three point does a lot better job. ;)
Paul Allwood
Jul 8, 2025
775
1,407
I think you may be right. The next thing I was wanting to add to the single tine ripper I made was something to help clear the trench rather than leave the spoils in there. The pic you've shared (thanks) looks better than the dodgy pic in my head. I was thinking that if make it removable I can run through with just the tine first, then add the extra bits to clear it out. Some areas here are hard and rocky, some are quite soft, so wouldn't necessarily need the same approach every time.
The next big question - this or a backhoe next ?
Too many projects.
7,680
If you go to a rear design you could use the channel piece (now on the front) as a tool to clean the crumbs out. Just have it mounted so you can drop it into the ditch (straight down) and pull forward to clean.
Chanceywd
Mar 26, 2021
876
869
central ny
I have one of those I bought many years ago from Central Tractor, a chain that was around here like TSC.
It came with that and a separate single shank you switched out with a couple bolts.
I used the shank to pull a path thru to put in a LP line. After the first pass I pulled in some pex tubing and then pulled the copper line in that with a steel cable I threaded thru.
I figured that using the shank that way would tell me if I was going to hit any sizable rock before diggin a trench with the backhoe, because I didn't have the backhoe mounted.
Worked quite well and didn't need the backhoe.
I want to take a curved piece of pipe or emt and mount that to it so i could bury an electrical cable at the same time like the phone company does with a vibratory plow. Have some work to do at my son's place where that would be helpful.
Bill
