No power to glow plugs on B7100D
USMC8999
B7100D
Jul 26, 2023
22
Oklahoma
I bought a old B7100D that has issues. The first issue i am trying to tackle is getting power to the glow plugs. I have power leaving the switch when switched to heat the glow plugs but nothing a the hot wire on the plug. Is there a fuse or something I should look for next or just start tracing wires?
3,126
I would suggest that the glow plug indicator is bad. It is just above the key switch on the right side of the dash. Or possibly a fuse is blown?
Here is the diagram of the tractor showing the part (#8).
You can try this test to see if that is it (assuming everything else is working properly):
The heat position runs through the glow plug indicator but then power is applied to the glow plugs when in the start position. So hook a meter positive lead to the glow plug buss bar that connects them all together on the top of glow plugs, turn key to the heat position and you say no voltage. But then turn the key to the crank position (you don’t have to push clutch pedal down but you can if you want the engine to crank). You should see around 11 Volta if the engine is cranking and 12 volts if the engine is not cranking.
3,126
If you just want to power the glow plugs to try to start engine that is possible but can burn out the glow plugs if held too long.
Just ask if you want to know how.
11,182
There is no fuses on the Glow plug circuit.
FYI: The glow plugs are powered in pre heat via the glow plug indicator and straight when starting.
USMC8999
B7100D
Jul 26, 2023
22
Oklahoma
Ok.
I will certainly give this a try. Thank you.
3,126
11,182
  • Angry
