Front PTO shaft options
b454rat
B7100HST B6100
Dec 10, 2022
67
Windsor NY
Not sure what section to put this in so I'll try here. I'm in the process of putting hydro steering on my B7100. The steering gears are pretty much gone, so figure now be the time to do it. Rather than use the tractors hydro, going with a separate system, might be a pain and a blessing at once lol. I want to run the pump off the front of the tractor, there is room, and pumps seem to be small enough to fit behind the bumper. The 7100 has the splined hub attached to the balancer, but is the 21 or 22 spline for the unobtanium snow blower shaft. My 6100 has a snow blower, but doesn't have this adapter, the shaft just slides on the splines on the balancer itself. I'm looking for a way to mount a shaft to either directly to the balancer, or the adaptor. Seems both shafts are unobtanium.
3,052
See this thread that discusses several options
10,953
No balancer on that engine just a pulley
If you have the adapter that uses the three bolts to mount to the pulley, you can use a Lovejoy that fits the adapter and use that.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
129
118
Lopez Island, WA
See discussion about "shrink disc" in various threads...
10,953
The lovejoy you would use would clamp onto the adapter not the crank splines.
b454rat
B7100HST B6100
Dec 10, 2022
67
Windsor NY
I looked at them yesterday and still don't see how they would go on. Must be Im missing something lol.
barts
Feb 10, 2015
129
118
Lopez Island, WA
Here's a couple of pictures of the adapter I made for driving a hydraulic pump from the front spline on our B5100. The round aluminum part is a shrink disc that elastically squeezes the adapter onto the spline. The adapter is a piece of stress-proof steel, which is a very close fit onto the spline.
10,953
You can use this style too just drill holes and attach to adapter. ;)
b454rat
B7100HST B6100
Dec 10, 2022
67
Windsor NY
So just use the 3 bolts to hold it, not the splines. There isn't gonna be alot of twist force or whatever want to call it....
b454rat
B7100HST B6100
Dec 10, 2022
67
Windsor NY
I think i found a shaft, even comes with snow blower lol. Next problem (more of a question) is what pump do I need? JD won't tell you a thing, so don't what size to get. .50 CI, bigger smaller, don't want it too fast, but don't want snail steering either. Searches have most using a p/s pump or using the tractors...
Donystoy
Dec 10, 2013
734
377
Binbrook, Ontario
I would think that 2 gpm should be the maximum which according to specs I have looked at would be around .18 cubic inches at 2000 rpm. Lots more folks here with a lot more knowledge than me with hydraulics.
7,197
The answer depends on your PS unit. If you have said what you are using I missed it.
b454rat
B7100HST B6100
Dec 10, 2022
67
Windsor NY
JD 318 valve and cylinder. The cylinder gonna be too short, but just want to get in and working, then swap it out once I find one.
7,197
I know very little about that steering but a quick sesrch indicates the hydrsulic pump on a JD 328 produces a max flow of 3 GPM.
ISTR we had a similar discussion about these steering valves and there are 4 and 5 port variants ???
