B-2032 front blade frame installation question
BiggB
B7100, B2030 front blade
Mar 20, 2026
New York
Good afternoon all
I’m trying to install as the title says a B-2032 front blade frame on my B7100 4wd the rear section is obvious by it’s shape but the front portion I’m having trouble getting it lined up it seems to be hitting the pinion case and riding on the axle housing. Now there are 3 holes in the frame but only 2 seem to have the proper alignment on the tractor frame but there are 2 sets of “properly spaced” bolts the one where I’m trying now about the middle of the engine and the other blots are at the rear of the engine. I think I have to do some trimming but don’t want to just start cutting without farming the knowledge base first IMG_0890.jpeg IMG_0894.jpeg IMG_0895.jpeg
Caden
1979 B7100
Apr 16, 2026
37
14
This may or may not still be relevant, but -
As far as I know, on the B7100, the hydrostatic models (HST & HSE) are several inches longer (6 maybe?) than the one with manual transmissions (D). If the blade originally was fitted one or the other, that may be causing your misalignment issues. Just a thought.
If you can weld, I see no issue with cutting the interfering crossmember out and moving it back some.
BiggB
Mar 20, 2026
New York
It was my error I needed to use the rear 2 and 1 of the front ones to bolt it on I’m not sure where the brain fart occurred but I cleared out the fog lol
