One piece gasket or RTV for a rotary tiller gearbox cover?
trackman23
MX4800
Nov 22, 2023
119
22
NC
I have a 6’, lowrey rotary tiller with a leaky side gearbox that needs to be fixed. Is this a repair that is best made with a factory, one piece gasket or with RTV?
thx!
Caden
1979 B7100
Apr 16, 2026
104
45
Personally I'd go with a regular one piece gasket and probably put a very light coat of RTV on both sides of it.
If you cannot find a gasket, then you could use RTV, - but you after applying, make sure you only very lightly tighten the cover for the first, say, couple hours.
That way, you don't squeeze out all the RTV before it has a chance to "set up". Then tighten normally.
Either way would probably work. Hope this helps.
5,091
I have never used it before, but have read something about a product called “corn head grease" as a substitute for gear oil in certain situations like yours.
It “allegedly” wont leak out, so you don’t have to take off the cover at all.
Just a thought……Maybe someone with “real world” experience will chime in….
EDIT: My personal experience, having been a Transmission and Axle mechanic in a previous life, has been that gaskets are “in general” a better solution than RTV/Silicone, you just have to torque them properly.
6,932
thx!
Thats about as low tech as it comes. Gasket prefered but probably a gadzillion covers like that have been installed with this.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,088
1,085
E.
I would vote best to get factory gasket if you can.
If not in this instance I would have 0 worry about a liquid gasket solution either.
trackman23
MX4800
Nov 22, 2023
119
22
NC
Thx folks. I may try to add RTV as mentioned to a factory gasket. Upon further investigation, the times of my Tiller must have picked up a rock and sheared off the backend of one of these cover bolts, which also bent the metal a bit, so I will need a little bit of extra help from that RTV to get everything sealed again.
