Blades for RCK60CA finishing mower.
jjanmaat
BX1860, RCR60CA Finishing Mower
Mar 24, 2011
Kelowna
Hi folks.
I've got a 60" finishing mower I use with a BX 1860. The mower is an RCR60CA. It is a 21 3/4 inch blade, part number 70080-91059. I've attached photos.
The local Kubota dealer can order the blades, for a total cost of about $500 Canadian dollars. Lots of way cheaper blades online. However, they don't have quite the same mounting hole, and are an inch shorter.
Anyone have experience with an alternative?
Thanks,
John.
Bee-Positive
Nov 16, 2022
934
905
Amsterdam, NY
The oval holes for those blades just don't look right, but I've been wrong lot of times in the past.
Call Messicks to see if these are correct.
jjanmaat
Mar 24, 2011
Kelowna
The oval hole fits onto the oval receiving end of the mount (see attached). The hole is 1 1/4 inch along the widest dimension, so a round opening might work. May need to do something to get the friction between the washer and the blade.
10,877
That is a RCR60-CA Deck
It is not a USA deck CA ONLY and is not an RCR60 deck.
Messicks can not help him.
