Speed25
L2501(sold) - BX25D
Apr 23, 2024
313
491
NC
Yet this guy has no problem taking his 16 wheel cement mixer through an old tobacco field and down a narrow path to close a long abandoned well. No hesitation. No spotter. No damage to anything. All drivers are not equal. View attachment 172324 View attachment 172327
Not all mixer drivers are equal either. We had a Loflin driver roll his mixer (fully-loaded) on a job in Kernersville years back. Butch was pissed! :ROFLMAO:
Mark_BX25D
Bx25D
Jul 19, 2020
2,083
1,593
Correct - as soon as the ground dries up I will split it and and roughly stack it in open rows to air dry. Come late summer I will put in the section of wood shed that I emptied this last winter. My shed holds two winters worth.
gg
And THAT, ladies and gentlemen, is the RIGHT way to do it.
Most people burn green wood. I used to think a year was good. I was sure all those "two years!" preachers didn't know what they were talking about.
Then I got some two-year wood, and realized how wrong I had been!
Most people don't even season for a year. Cut in spring, start burning that fall. Wrong.
Mark_BX25D
Bx25D
Jul 19, 2020
2,083
1,593
If I’d have bought the clamp on edge tamers (legit brand) I wouldn’t even take off the tooth bar at all. Mulch, dirt, gravel…… I leave it on. I built a loop to the driveway a couple years ago. Layed down the base 4” aggregate and reclaimed asphalt with the bar on.
I think you're better at controlling your angles than I am! 😁
(y)(y)
L35
Jun 13, 2010
694
805
CT
Shoot I go 3 years out. Lots of oak up here and that takes a while. I split on the large side also,
Mark_BX25D
Bx25D
Jul 19, 2020
2,083
1,593
Yep. Burns longer. Small stuff goes up the chimney too fast.
I like mine AT LEAST 4 inches, better is 6.
But if you are burning green wood, that's not going to work, so most people think it doesn't work.
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
153
295
Mark Twain Forest
The wind finally slowed below the howling-around-the-corners speed, and I sprayed for weeds. The first crop of dandelions already went to seed and disbursed.
Blue2Orange
Apr 3, 2025
396
276
Bayview Township
I can see most of my driveway again. In the woods any steeper sections facing S are bare. Trees are acting like big heat rods even on N facing pitches. A Robin showed up. A few Mourning Doves have arrived. So....
I removed the snowblower, greased and oiled all fittings. It now sits on a pallet in the garage waiting for next season. I hope. I didn't remove the chains off the tires. That would double jinx and ensure a late season dump. Chains off on Tax Day!
One thing left to do. Almost made it through a winter snowblowing season without picking up a single stone. My last or was it 2nds to last use of the blower ended up throwing a bit of gravel. Frozen hard ice surface sheared off with rocky gravel stuck to it as the blower sucked it in and either tossed it into the woods or dumped it forward for a repeat trip into the blower. Scratches left in the impeller housing are mostly black. Assuming primer layer? For the more grey silver scratches I'm assuming down to metal? Does Rustoleum spray paint need a primer layer?
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
Ste Geneveive county, MO
I received a load of cull logs yesterday and today I worked on bringing them down to the staging area by the house. The logs were dropped off about 2/10ths of a mile at the end of our driveway on the private road.
I was able to move them all today. I only had to cut one into two logs, it was about 18' long.
I had a little luck picking up two logs
Reactions: 12 users
6,149
Final task on the reclamation of the old auger. Storing it in a manner that provides safe and efficient installation and removal. As many of you know, three point augers are infamous for being a PITA to remove and install.
After some thought about various methods to prop it up sitting on the ground, decided to hang it from the shed roof framing. Took it off, put it back on, then took it off again just to make sure it worked as expected. Hanging it allows easily moving it a bit in all directions which is quite helpful installing it.
Took longer than it probably should have partly because I started with a vague plan and used stuff that was already on hand.
Reactions: 13 users
Bmyers
May 27, 2019
3,580
4,745
Southern Illinois
Continued to work on clearing up the old corn crib area.
Got most of the building removed from the site.
Still need to work on getting it leveled so I can then bring in the rock before we get the connex delivered.
During the project of moving the old building pieces to the burn pile, I noticed a shiney bolt in the pathway. I got out and picked it up and thought this isn't going to be good. Started looking over the tractor and found that the bolt was from the rear tire rim. Well, I figured I was done for the day, no way I would find the washer and nut. Looked around just a little, didn't see anything, so put the tractor up and started to head to the house. Walked past where I found the bolt, about three feet past that I noticed a washer. Well, at least I won't have to buy a washer now. Walked about six feet more, there was the nut.
Went back to the barn, put the bolt back on the tire and finished hauling the stuff to the burn pile.
This weekend will break out the torque wrench and go through all the bolts on the tires to make sure nothing else is loose.
I will have to admit, I had never checked those bolts. (see picture below)
Why I didn't think about checking those, I have no idea. Was really good about checking the others and making sure they were torqued. Lesson learned and all it cost me was a few minutes of time, so I was fortunate.
Reactions: 12 users
Blue2Orange
Apr 3, 2025
396
276
Bayview Township
Moisture meter. Unless the meter is way off a way to checking your wood if concerned. This past winter mostly burned some of the too old firewood. Checking the wood the meter noted "Lo" vs. giving me a % moisture content. At least with red oak if burning too dry you don't get the max btu. I look at that not burning gets you zero btu.
edritchey
2026 Kubota T2290-48 2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75
Jul 19, 2014
1,179
938
Wellsville, PA
Added a decent volt meter and some power ports to my ZD1211 now it has USB 3.0 and USB “C” ports don’t know why Kubota doesn’t add them but it works.
biketopia
Feb 15, 2024
415
438
Warrenton VA
I was all over the place this year with my wood moisture content. Was my first year fully supplementing with wood in a fireplace insert. Definitely saved on propane, but could of been even better. I had red and white oak that was just right, some that was a little on the wet side, and some ash that was bone dry. Working on finding wood in the area to grab. I have 5 acres, but only like 6 trees, all of which are cedar or dogwood. If I buy pre-split wood from the locals, I might as well just fill the propane tank...
11,692
Picked up my friend's new snow trip blade this afternoon. It's the Land Pride STB1584 so the smaller brother to my STB1596. I sent my friend a photo to show proof of life and he suggested that I leave it in the trailer since he's fairly confident he has the 2" ball needed to pull it back to WA. 😂
Reactions: 10 users
6,149
First mowing of the season at our house. Haven’t had to mow at the other two houses yet as they have much more shade so they’re a couple weeks behind. IMG_8463.jpeg
Reactions: 10 users
GrumpyFarmer
4,999
First mowing of the season at our house. Haven’t had to mow at the other two houses yet as they have much more shade so they’re a couple weeks behind. View attachment 172466
Same here…I made the first today mow too.
probably sneak a till in within the month…if I get bored the wood chipper will be soon to follow.
Shawn T. W
Dec 9, 2024
699
1,294
SW Missouri Ozarks
I did my second mowing on my regular lawn Tuesday, haven't mowed the field yet, probably next week when I'm home, also tilled on Tuesday ... But, no orange paint involved! 😞
11,692
I've never owned a zero turn but am curious as to the advantages of that cute little guy over a zero turn. Is that you can run other attachments?
I haven't started cutting yet and will probably spray Milestone before any cutting. If I cut I'm concerned that clippings will prevent the poison from getting to the leaves of the knapweed.
