Alternators
3,037
What problems are having? No charging circuit?
Arnorteo
Kubota b1502
Apr 9, 2026
Ravenswood
Thanks for the diagram, tells me most of what I want to know. My Battery runs down over time - usage is infrequent so it may be that the charge just drops. The charge light comes on and off ... Indicating a malfunction of some kind, but because of underuse I can't say for certain that it never charges. At least I now know repair or replacement is pretty major. Thanks again.
2,964
It is probably the regulator that is bad.
10,777
You can rule out the dynamo really fast with an AC meter, disconnect the 2 wires coming off the dynamo then connect the meter to those leads and start the tractor turn it up to a high RPM and you should see 22VAC or thereabouts on those wires.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
127
116
Lopez Island, WA
On our B5100, the regulator was bad; the alternator was producing plenty of AC.. A new regulator from Amazon was $25 and it has worked fine for the last 5 years.
Arnorteo
Kubota b1502
Apr 9, 2026
Ravenswood
Belt may be slipping
too low RPMs
lousy ground on rect/regulator
bad battery
corroded terminals and wires
Thank you
I've ruled out the bad battery and terminals, think it is probably the regulator. Just gotta take time off from eternal landscaping to get to it?
