M7060,.. Are wheel weights a must & a creeper gear?
11,571
you are 100% correct that using when tractor loads are less than moderate.
Low range on trucks and creeper gears on small tractors like the M's can be two very different animals.
In the Kubota tractor world creeper is only for precision work when there is low or at most moderate loads on the transmission and drive train.
They warn that in high torque situations bad things can and will happen wickedly quick. Its just not for very HD uses when traction is strong.
YMMV
I think @MapleLeafFarmer's post should be highlighted again. Thanks for your input on this thread, and hopefully this has helped @Stitchit1 get way ahead on the learning curve and not take four years to learn what creep range is for. 😂
I will say that I'm still going to get the tractor on/off the trailer using creep range. It's just way more controllable that way, and I don't see a problem doing that. But as has been demonstrated, what the heck do I know.
@MapleLeafFarmer, can you please sign off on my using creep range to get the tractor and folding cutter on/off the trailer? 🤪
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,068
1,062
E.
how the frack would I know. 👍
I am probably one of the least technical people on this site.
I graduated grade school because my marks in farming class were really high and the physical education teacher took pity on me as he knew I wouldnt graduate without his high marks. Our farms first tractor had tracks... steel tracks not those new rubber Camso pods the Hutterite Colonies use.
You want to know who makes the best rubber boots that wont wear out or something learned from seat time Im your man. Understand why engineers do what they do, technical drawings, etc... i m definitely out of my league.
BTW... the answer is Baffin. They unarguably make the best rubber boots.:coffee:
11,571
I was joking (sort of) but no pressure. I don't think that the tractor is under any kind of stress getting on/off the gooseneck when in creep range, so I'll continue to use it for that, as well as any other situation where slow as a snail is good. (y)
SDT
Apr 15, 2018
3,620
1,347
Yes, creep range is just fine for loading/unloading from trailer. It is also ideal for pulling your tobacco setter and similar easily pulled implements that demand very low ground speed.
PaulL
B2601, MX5200.
Jul 17, 2017
2,753
1,755
NZ
All great information.
Seems to me that when you reduce the gearing you increase the torque (gears are a torque multiplier). But if you were running full revs, and actually tried to put all that torque on the ground:
  • I doubt you'd have the traction for it, even in the dry. It's a lot of torque. So probably you'd break traction before you broke the tractor
  • If you have the traction and something is producing enough load to put force on the machine - like you've put a chain around a stump and you're trying to pull it out - then you'll break something
Obviously you could build creeper gear that was stronger. But it'd cost more, and I don't think there are many people using tractors in that way. If you want to pull out stumps you have a bulldozer, or maybe an excavator.
As others have said, the aim of the creeper gear is simply speed. If you have a lettuce planter, and that lettuce planter has to run at 540rpm (I presume they're like every other PTO driven implement and require to be run at 540rpm), and they also need to be run at 0.7kph, then you need gearing that lets you run at 0.7kph at PTO revs. There's no material load on the drivetrain - you're not dragging an implement through the ground, the gearing is purely about speed over ground.
11,571
I think we all knew about the significant reduction in ground speed in creep range. I asked these questions four years ago when I bought my M6060, both on this forum and at the dealer, and given my experience with my Jeep and various trucks over the years and the notion that low range is for serious pulling, I assumed that there was some kind of translation issue with the operator's manual.
After this discussion, and comments from @JasonW and @MapleLeafFarmer it's so much clearer now and I appreciate the constant learning that this site offers. I've never used creep range to do any pulling type work, but in my head I thought it would be the best choice if I were pulling a mole plow or sub-soiler but that's not the case anymore. As I mentioned, I do use creep range for at least two situations, and have found that it works well when climbing a steep hill in deep snow where wheel slip is an issue. Reducing the rotation speed of the wheel can help with traction ... not a shocker I know.
I will say that the M6060 has no problem pulling a box blade uphill in L1 or L2 with the scarifiers engaged, and the tires will dig holes if forward motion stops. It's a torque monster for sure ... comparatively of course.
