L3901 4X4 axle leak help
1Sarge
L2550 Tractor
Jun 25, 2009
Houston, Mississippi
I bought a L3901 HST last year with a little over 500 hrs on it. I have an occasional leak on the left side of front axle. Axle has check plug on left and fill pug on right side. After operating for a while if I remove the check plug it appears to have built up pressure in the housing. I see no vent for the axle housing but is this normal? Is the fix a new seal?
3,153
I would assume there is a vent somewhere on that case and if there isn’t one then I would install one somewhere since pressure building up will cause leakage.
Look at the illustrated parts lists here or wait for a more informative answer.
3,781
2,184
There is no vent in the front axle; it does not need one. Yes, it is common to build pressure as the fluid warms and expands.
The fix is to repair the failed seal.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,199
1,189
E.
I had similar problem.
My dealer told me to try this fix before going the seal route. He said the UDT/S-UDT used at the factory in the axles is very light / thin. So drain and replace with 80w/90 gear oil which is thicker. My manual said both were suitable.
I did and never had the irritating small drip again. Sold the tractor 10 years later. Not sure if this still applies but sure a cheap / quick / easy test that can be made.
